she started!!!....but she is eating the timing belt! why?
Old Feb 25, 2003 | 05:50 PM
fastludeh22's Avatar
Default she started!!!....but she is eating the timing belt! why?
ok so i think the problem has to do w/the tenisor. i converted to h23 tensior using a part list off here, and my helms manuel. when i put it all together, the timing belt was really tight, but thats how tight the spring was pulling it.
it is eating the timing belt from the top side though. any ideas?\
i have it on video, but you cant see the prob., just smoke, and the files are prob. big.
Old Feb 25, 2003 | 06:56 PM
Boostless97Lude
Guest
Posts: n/a
Default Re: she started!!!....but she is eating the timing belt! why? (fastludeh22)
i bet i know.... there is a big *** washer that goes agains the block... in between the flared part of th shaft that the tensioner goes on, it's a bronzish/gold color, and it's huge.... i forgot to put that thing on before i screwed the shaft in, and it ate my timing belt off
Old Feb 25, 2003 | 07:10 PM
BoostedH23a1's Avatar
Default Re: she started!!!....but she is eating the timing belt! why? (Boosted97Lude)
dont drive it.. if it pops u will be getting new valves and a valve job..
were the teeth lined up if they are a **** hair off they will get chewed up
Old Feb 25, 2003 | 08:35 PM
Default Re: she started!!!....but she is eating the timing belt! why? (BoostedH23a1)
yes the belt was on right.
can anyone host a pic for me, i think i know what boosted 97 is talking about. where did it eat the belt from, its eating the top flat side.
Old Feb 25, 2003 | 08:57 PM
PrecisionH23a's Avatar
your welcome
Old Feb 25, 2003 | 09:09 PM
satan_srv's Avatar
Default Re: she started!!!....but she is eating the timing belt! why? (GudeH23a)
NICE! I just checked my H23 manual tensioner parts. Got that!
Old Feb 25, 2003 | 09:34 PM
4gen's Avatar
Default Re: she started!!!....but she is eating the timing belt! why? (satan_srv)
heres the pic for fastludeh22
[Modified by 4gen, 11:48 PM 2/25/2003]
[Modified by 4gen, 11:49 PM 2/25/2003]
Old Feb 25, 2003 | 10:23 PM
Default Re: she started!!!....but she is eating the timing belt! why? (4gen)
yep, you have the washer on wrong, you have it on the outside near the nut, it should be flat against the block like it looks like in my picture. i actually ran into this problem before, just fix the washer problem and you'll be good to go.
Old Feb 26, 2003 | 05:33 AM
damn, thanks guys, at least i know what it is, but how the hell am i supposed to do this w/it in the car!
what a waste of a 180 doller belt!
Old Feb 26, 2003 | 10:13 AM
Boostless97Lude
Guest
Posts: n/a
yep, you've got that big *** washer on the wrong end of the shaft.... i did the same damn thing, ruined the belt, $50 instead of $180, cause i had an OEM..... but yeah, that your problem, take the tensioner off and put the washer how Gude has it pictured, and you will be straight
[Modified by Boosted97Lude, 2:15 PM 2/26/2003]
Old Feb 26, 2003 | 02:47 PM
dont worry, just take the tensioner assembly apart the same way that you put it together the first time. remember, you'll have to remove the driver side motor mount to get the old timing belt off and the new one on. make sure you have a manual handy for the job. if you take your time and dont rush you dont have anything to worry about.
another word of advice, there is a small little bolt that fits into the tensioner assembly to keeps the pulley in position....
its in the red circle. If you ran your car for a while, then im almost 100% sure the oil balancer shaft pulley grinded the little alignment bolt down and it will look like it has a flathead screwdriver mark indention in it. if it does, just sand it down so it will still keep its cylindrical shape. If its bad, go to honda and buy another one, which is what you should do. I made the same mistake but luckily i caught the mistake before i put the motor in my car.
[Modified by GudeH23a, 6:54 PM 2/26/2003]
[Modified by GudeH23a, 6:55 PM 2/26/2003]
TheCrimsonGhost666
Oct 10, 2010 01:10 PM
slide inside
Oct 22, 2009 09:25 AM
stickyfingers
Jun 10, 2005 04:18 AM
JiggaFan
Feb 21, 2003 09:52 AM
