ABS light comes on interm.///brake problem? 93 accord ex
My ABS light comes on every once in a while and stays on until i turn off the engine. when I'm coming off an exit ramp, i get a slight vibration when applying the pedal and then i push it again and it goes away. i've been told it might be an abs pump. i've replaced the abs sensor and the front rotors are not warped at all. can someone please help me? ive taken it to a shop a number of times and they havent been able to find the codes. i can't afford to take it again unless i know what the problem is. any info is better than nothin! thanks guys
What code does it have stored? Check it the same way you do a CEL.
[Modified by Chiovnidca, 9:35 PM 2/27/2003]
coolswimmerjon
Jan 31, 2016 01:05 PM
