15 x 7 rims what offset for a 99 SI?
The closer you are to 45 the greater rubbing you will ahev on the inside of the tire when turning at full lock.
The closer you are to 38, the more chance you will have of the front and rear tires rubbing the fender edge.
But in most cases, the rubbing is minimal in front, but the rubbing in back could require you to roll your fenders or trim them up (which I did)
SiClone
Apr 21, 2002 12:23 PM
