I got a Brake Problem!!!
Old Feb 25, 2003 | 02:47 PM
CIVIX's Avatar
Default I got a Brake Problem!!!
My brake lights don't work but My turn signals & Reverse lights do and my third tail light doesn't light up either. I have checked all the fuses that I could think of and I haven't found a blown fuse or anything!! Can anyone help!!!!
Old Feb 25, 2003 | 03:33 PM
mph6563's Avatar
Default Re: I got a Brake Problem!!! (CIVIX)
Maybe the brake pedal switch or its wiring is bad. If you have cruise control, does pressing the brake pedal disable the cruise?
Old Feb 25, 2003 | 06:00 PM
CIVIX's Avatar
Default Re: I got a Brake Problem!!! (mph6563)
Yes it does disable the cruise control!
Old Feb 26, 2003 | 04:22 PM
CIVIX's Avatar
bump Please help me out I got a ticket about this! $85 dollars worth
Old Feb 26, 2003 | 04:29 PM
rathead's Avatar
did ya check the bulbs?
Old Feb 26, 2003 | 04:56 PM
EG6-SiR's Avatar
New User
Default Re: I got a Brake Problem!!! (rathead)
Get a meter and check all the wiring.
Old Feb 26, 2003 | 04:58 PM
turbo_era's Avatar
Default Re: I got a Brake Problem!!! (EG6-SiR)
check the cluster bulb
Old Feb 26, 2003 | 06:41 PM
CIVIX's Avatar
Default Re: I got a Brake Problem!!! (turbo_era)
I've checked the bulbs the bulbs are fine! My Turn signals work but my Brake lights and my Third brake light doesn't work??? How do I go about using a volt meter???
Old Feb 26, 2003 | 06:54 PM
EG6-SiR's Avatar
New User
Just check each segment of wire, check for kinks or breaks in the wiring, check it in segments until you find out where it's gone dodgy. Just cut open the insulation and check it that way and tape it back up after it checks out
Old Feb 26, 2003 | 07:14 PM
built562's Avatar
it looks like its going to be the brake light switch. check under your brake pedal, they go out from time to time.
Old Feb 27, 2003 | 03:17 PM
CIVIX's Avatar
Default Re: I got a Brake Problem!!! (akumaracer)
I replaced the Brake light Switch and it wasn't that either???? Does anyone know what else it could Be!!!!
Old Feb 27, 2003 | 03:51 PM
globlctzn's Avatar
I just had this same problem with my eg. I had no idea I had no brake lights, untill someone brought it to my attention. All three lights were out (2 tails and 3rd brake light), but my horn also was not working. Didnt take me long to realize they are on the same circut. I changed a blown 20amp fuse out in the under the hood fuse box and bam I have brakes and horn. So see if your horn works, and start trying to isolate the problem in the circut.
vtecphean
Lighting
Apr 19, 2012 11:34 AM
keepitngga1
Jul 18, 2008 10:26 PM
RemoveGiantWingOnYourCar
May 4, 2006 06:26 AM
Gonzo_SiR
Audio / Security / Video
Jul 19, 2003 02:03 PM
92accord4life
May 2, 2002 02:02 PM
