NASA tech "quick release" net requirement
uncleben's post asking about window nets got me doing a bit of searching about ways of satisfying NASA's tech rule about the net being a "quick release" system.
does a simple spring loaded top bar constitute a quick release where you just pull one end back out of the mounting tab and release which frees the other spring loaded end? or does it require the use of a latch like a gm seatbelt buckle or mechanical latch?
I would certainly think that just about any spring-loaded, one-second-to-remove net setup is fine. I think this is going to be one of those "safety grey areas" like we've talked about elsewhere. Seat mounts and "mandrel bent" cage tubing come to mind.
Steppin Razor
Jun 5, 2003 05:45 PM
