heat problems, do you experience these too or is your heat pro like mine used to be?
Old Feb 25, 2003 | 01:57 PM
91_civicsi's Avatar
Default heat problems, do you experience these too or is your heat pro like mine used to be?
well when im idling or stopped at a light if the heat is on like face or vetn,,, it gets cold like air conditioning air, then when i start driving again it gets hot again, weird if you ask me :S anyone know why this is? or anyone else ever experience any problems like that?
Old Feb 27, 2003 | 07:08 PM
smokeeater2894's Avatar
Default Re: heat problems, do you experience these too or is your heat pro like mine used to be? (wpg_civics
sounds like a coolant air pocket in your cooling system, rpms are lower at idle and this pocket can set in under your sensor, causing a shutdown reading, might try bleeding your system, if not then your heat door could be slammin shut cause vaccuum is highest at idle
1fastvtec
Jan 26, 2015 05:12 PM
scrolanky
Nov 5, 2008 07:21 PM
fraknstien
Feb 5, 2007 05:19 PM
NightHawkC5
Jul 31, 2003 09:23 AM
