f
Old Feb 25, 2003 | 12:29 PM
duRritztiNy's Avatar
Default FS: KODAK DP850 Ultra Digital Projector
Features and Benefits
Ultra-Convenient
You’re on the road, sharing what you know. The DP850 Ultra can help. Designed for maximum portability, the DP850 is just under 10 lbs. Its extra-small footprint, about the same size as most laptops, gives you plenty of room on your set-up table. The soft-sided carrying case makes it easy to take the DP850 wherever you and your laptop go. With color-coded cables and auto-synching, you can set up for a presentation in minutes, not hours. Travelling internationally? The DP850 is built for multi-voltage operation — no need for a voltage converter.
Kodak's Exclusive Image Manager
Push the button and we’ll do the rest. We’ve made it so easy to get the best possible result – whatever you want to project. Kodak is the obvious choice for pictures with stunning clarity and realistic color. You’ll also get eye-popping graphics and clear, readible spreadsheets. It’s easy. No more high-tech tweaking. Relax. You’ll look great!
Ultra-Bright
Designed for use in ambient light conditions, the DP850 delivers SVGA (800 x 600) resolution. The 450 ANSI lumen light image gives you clear, easy-to-read text and images. Furthermore, the DP850’s 2,000-hour cool-running lamp means you could run this projector 24 hours a day for nearly three months before changing the lamp.
Quality Digital Images
To give you true-to-life images and outstanding color and quality, the DP850 uses award-winning Digital Light Processing (DLP) technology. Video images have the look of film. Stills and slides from your computer feature rich, fully-saturated colors.
1.5x Power Zoom
No more adjusting the size of your image by moving the projector forward or back. With the DP850’s power zoom, you can enlarge or reduce your projected image with a touch-pad at the projector or with the remote. It’s designed with presentations in mind.
Powerful, Interactive Remote Control/Remote Mouse
Once your projector is plugged in, the remote control lets you do the rest. Use the projector’s multi-functional infrared remote control, which is included, to control a computer during a presentation, in place of a mouse. With the touch of a button, turn the remote into a pointing device.
TV Tuner
Connect directly to broadcast signals from a cable or satellite receiver wherever you may be in the world. The DP850 has an available snap-in TV tuner that lets you project the latest news, sports, weather, and programming up on the big screen.
Super Sound
A true multi-media projector, the DP850 features a high-performance 10-watt loudspeaker with an optional connection to your external sound system. Multiple-channel input allows you to switch signal input devices without plugging and unplugging cables.
Digital Camera Option
Choose the DP850 Presentation Kit and you’ll also receive a KODAK DC220 Zoom Camera. This easy-to-use camera lets you quickly and easily capture digital images and insert them into your laptop presentation files. Or, plug the camera directly into your projector for a pictures-only slide show.
Specifications
Weight: 9.9 lbs (4.5 kg)
Color Palette: 16.7 million colors (24-bit)
Resolution: SVGA (800 x 600) with compression for XGA (1024 x 768) digital images
Display: Single-chip DLP
Aspect Ratio: 4:3
Response Time: 16 ms
Contrast Ratio: 230:1 (ANSI Checkerboard) 500:1 (ASNI Full on/off)
Computer Compatibility: SVGA, Modes: 56 Hz – 75 Hz; VGA, PC, MACINTOSH, POWERBOOK and others
Video Compatibility: NTSC, SECAM, PAL B/D/G/I/H/N/M
Projection Lamp: 120 W Metal Halide UHP - Ultra High Performance
Lamp Life: 2,000 hours
Brightness: 500 ANSI lumens, typical
Lens: Motorized zoom 1.2:1.7 with 17-degree keystone adjusted image
Focal Range: 5.74 ft (1.75 m) – 16.4 ft (5 m)
Zoom Factor: 1.5x
Uniformity: 85% image center-to-corner
Image Configuration: Plug-and-project auto image positioning, auto tracking and auto synchronization
Audio System: Built-in 10 W loudspeaker
Inputs: Full digital connectivity
Computer (EVC plug)
S-video (MiniDIN/4pin)
Composite video (RCA)
Stereo Audio L/R (RCA)
RS232 connectivity
Outputs: Stereo Audio L/R (RCA)
Vertical Frequency: 48 Hz – 85 Hz
Horizontal Frequency: 15 kHz – 60 kHz
Power Input: 100 VAC – 250 VAC, 50 Hz – 60 Hz, full range
Operating Temperature: 50°F (10°C) to 104°F (40°C)
Dimensions:
13.2 in. (W) x 8.86 in. (D) x 5.12 in. (H)
[335 mm (W) x 225 mm (D) x 130 mm (H)]
Options: Snap-in TV tuner
Give me a price for the KODAK DP850 Ultra Digital Projector.
Can contact me at
Aim ssrpimpsta
Email s0uthsideracing
You want to contact me cell 832-832-6067
[Modified by SouthSideRacing, 9:30 PM 2/25/2003]
Old Feb 25, 2003 | 12:48 PM
Mike M's Avatar
Founding Member
Default Re: FS: KODAK DP850 Ultra Digital Projector (SouthSideRacing)
How Nice! Ever think of reading the rules though??
LOCKED
EDJames22
Mar 7, 2008 06:00 PM
turbociv910
Jan 2, 2006 06:13 PM
