Dead Clutch Pedal
Old Feb 25, 2003 | 09:49 AM
tomhyl1's Avatar
Default Dead Clutch Pedal
Replaced clutch & pressure plate on 92 accord. Bled system via release valve. Clutch pedal goes down and does not return. Must reach down to return it. Replaced clutch master cylinder and release valve. Checked pedal springs, they look ok. Any suggestions?
Old Feb 25, 2003 | 10:09 AM
krzyaccord's Avatar
Default Re: Dead Clutch Pedal (tomhyl1)
I had the same problem with my 97 accord. I just back bleed the system from the slave cylinder and it worked. Hopefully it might solve your problem.
Old Feb 25, 2003 | 03:15 PM
tomhyl1's Avatar
Default Re: Dead Clutch Pedal (krzyaccord)
Appreciate the info. I thought the slave and release were the same, just different terminology. Anyway I did bleed from the slave until only fluid came out repeately. Still no change. I'm probably forced to go to the dealer and get ripped off.
cleansi
Aug 13, 2012 05:21 PM
ducsaim
Jan 14, 2011 12:17 AM
96civic turbo
Transmission & Drivetrain
Jun 5, 2010 11:09 AM
jdubbs99
Jan 26, 2010 12:06 PM
smetzger
Mar 2, 2006 10:50 AM
