Did I blow my AGX shock?
Old Feb 24, 2003 | 09:41 PM
forever slow EG6's Avatar
Default Did I blow my AGX shock?
Whenever I turn my wheel left moving or parked I hear a loud groan and crunching noise. I also hear this whenever coming to a stop at a light and the cars weight shifts forwards. The noise is only in the front left side of the car, and I have already put the car on a lift at work. All bushings are intact, any ideas on what it might be? The shocks are 4 way adjustable KYB AGX gas shocks, a friend suggested a possible blown seal, anyone have this happen?
Old Feb 24, 2003 | 09:46 PM
Default Re: Did I blow my AGX shock? (forever slow EG6)
**selfish bump**
Old Feb 25, 2003 | 05:00 AM
CXHatchback's Avatar
Bump but it doesn't sound like a shock problem
Old Feb 25, 2003 | 05:45 AM
Zer0DazE's Avatar
sounds like a cv joint
Old Feb 25, 2003 | 06:40 AM
SoulSurfer's Avatar
Default Re: Did I blow my AGX shock? (Zer0DazE)
That would be my guess too. Does it make a clicking noise around corners?
Old Feb 25, 2003 | 07:29 AM
ScrapinSi's Avatar
Default Re: Did I blow my AGX shock? (LSDelSol)
Axle or Ball Joint is my guess....
Old Feb 25, 2003 | 10:55 AM
kay_animation's Avatar
jea, definately a cv joint. Do you hear popping noise to when you turn or feel vibrations when you accelerate?
Old Feb 25, 2003 | 04:00 PM
VRD^don's Avatar
yeah difently a cv joint. my buddie had that same damn problem with his..
Old Feb 26, 2003 | 02:10 PM
all bushings are intact, all cv boots are secure, no noise when accelerating. thanks for all your help. what are the obvious symptoms I can look for to see if the shock is blown or if the seals are toast?
rhdins
Nov 17, 2009 01:43 PM
cracker1252
Mar 2, 2009 05:28 AM
aZnAcCoRd02
Oct 29, 2005 10:53 AM
tw_itr01
Jan 24, 2005 08:33 PM
