What happens to EBC Green Stuff when used properly
Old Feb 24, 2003 | 06:09 PM
shawnhayes's Avatar
Default What happens to EBC Green Stuff when used properly
What they look like before:
And after a NASA HPDE at VIR:
Shawn
P.S. - all that crap about EBC greens not stopping well is bull. They stop fine. My instructor said "Your brakes kick ***." I know there are better track pads, but a good street/moderate track pad is these EBC's.
Old Feb 24, 2003 | 06:12 PM
Evs-One's Avatar
Solbros Owns Me
Default Re: What happens to EBC Green Stuff when used properly (shawnhayes)
you running stock rotors too??
Where'd you get them and how long are they "supposed" to last
Old Feb 24, 2003 | 06:18 PM
sammysnakes's Avatar
Default Re: What happens to EBC Green Stuff when used properly (Emerica)
i've never heard anything bad about them. mine are still in a box waiting for my rotors....
Old Feb 24, 2003 | 06:22 PM
EK MONEY's Avatar
Default Re: What happens to EBC Green Stuff when used properly (chainsaw)
i used them on my type R. red stuff... they worked badd *** on stock rotors. lasted a good amount of time and not alot of dust..
-Whitey-'s Avatar
arent they supposed to be very low dust pads? looks like alot of dust to me what pads are really low dust pads that perform well?
Old Feb 24, 2003 | 06:25 PM
tominos's Avatar
Default Re: What happens to EBC Green Stuff when used properly (-Panda-)
dang, can't even tell it's green anymore. how do they fare on the rotor wear?
Old Feb 24, 2003 | 06:27 PM
shawnhayes's Avatar
Not exactly.
1994 Prelude VTEC rotors - manufactured by Brembo, redrilled to 4 x 100 to fit the 92-95 EX hub.
I don't think you could exactly call those "stock", but they are conventional rotors.
I wasn't very happy with the pad that came "loaded" on my 1991 Accord Wagon EX caliper (the same caliper as on the ITR), so I wanted a better pad. After some research, I settled on the EBC green. I bought them from TireRack when I got my last set of Koni's, and they're supposed to last maybe about 75% as long as stock pads, but handle track abuse some better. A lot of smack has been said about the EBC greens since then, and I wondered if they were right. They weren't. Sure, they're not Panthers or Panther pluses, but those squeak like hell. Maybe an Axis metal master or Ultimate is a competative product.
The best part of the story is how the green backing plate of the pad is now black as heck (you can see it in the caliper).
Shawn
Old Feb 24, 2003 | 06:29 PM
shawnhayes's Avatar
Brakes from 120mph on the back stretch at VIR from braking marker 1 (!!!) generates major heat and dust. The fact that they brake and don't fade under that situation is a credit to the pad. Who cares about dust in that situation.
Shawn
Old Feb 24, 2003 | 06:32 PM
shawnhayes's Avatar
Default Re: What happens to EBC Green Stuff when used properly (tominos)
Seems to be pretty good. The rotors ARE a little scored after the day, but not horribly.
Shawn
Old Feb 24, 2003 | 07:49 PM
CXHatchback's Avatar
Sorry, but I don't know what I'm looking for in the second pic. Could you fill me in?>
Old Feb 25, 2003 | 03:24 AM
shawnhayes's Avatar
Default Re: What happens to EBC Green Stuff when used properly (CXHatchback)
See the area in the center of the caliper bracket? This is the EBC pad. Before I started the weekend, this was painted BRIGHT GREEN. It's now BURNT black.
EBC greens were really designed for this use. Not what they are bought for by most people, though. They end up on showcars all the time, because they were designed as a low dust performance pad. This attracts people who really have no need for that good a brake pad.
I just wanted to show off what they can REALLY do. They can brake well enough to generate enough heat to burn off the green paint they are painted with.
Shawn
Old Feb 25, 2003 | 04:57 AM
Gotcha.
I've always read mixed reviews on that pad, so I didn't know what to think about it. It has however, always been on my To-Try list, along with AEM, Hawk, etc. Probably going with AEM next.
I had Axis Metal Masters and I think they were just awesome, but more dust than I've ever seen from even cheap autozone pads.
Old Feb 25, 2003 | 06:17 AM
bikeboy80's Avatar
I was kinda unsure of using them too, but when Brian from Fastbrakes offered them to me with my 11" upgrade for real cheep I decided to go for it and i'm very happy I did I agree that I really don't think they really are a low dust pad, but who cares
Old Feb 25, 2003 | 08:44 AM
Solracer's Avatar
Shawn,
As you get faster and brake harder.. you will burn up the ebc's so fast.... Trust me I know I did my first track event last year @ Jefferson circut... and toasted my EBC greens so fast I was not funny... they were smoking big time when I came of track and were glazed heavily. Switched to axxis ultiames for the time being and they stop better than the EBC's and have help up at CMP, LMS, VIR-N and BVIR-Full. I am running stock brakes however are you? My next set of pads will be the cobalt friction pads, I think the are the GT-R1 compound.
P.s. I assume you had a good weekend? I saw you out there and meant to come by and say hi,, however my annoucing duties took precident.
[Modified by Solracer, 5:45 PM 2/25/2003]
Old Feb 25, 2003 | 10:54 AM
kay_animation's Avatar
Dam, i had so much faith in the pads. Now, i'll stick to stock.
Old Feb 26, 2003 | 03:12 AM
shawnhayes's Avatar
Default Re: What happens to EBC Green Stuff when used properly (Solracer)
Shawn,
They smoked pretty bad at the track. The "burning" as you note, has turned the backing plate that color. I expect them to burn up pretty quick. But, I must admit - they do brake well.
I bought a set of axis ultimates from Alan of Cobalt while I was at VIR, along with a bottle of smurf ***.
These are by no means stock brakes. Those front brakes are Prelude VTEC rotors with the Accord Wagon caliper (very close approximation to Type-R brakes).
I had a good weekend. I'm working a lot on getting entry speed "right". I either want to go too fast or too slow. As I find another area to work on, my entry speed changes because of the new technique, and it's frustrating.
Most interesting to see though is how good my car is. My instructor loved it. The straightaway power was amazing. The only thing that could accelerate with me was the Porsche. Everything else I had to lift so they could pass. The brakes ROCK. I have way too much brake for street purposes. This last weekend is the first time I've ever utilized them to their full ability.
Shawn
Old Mar 6, 2003 | 06:21 PM
owen_the_soyboy's Avatar
Old Mar 6, 2003 | 06:39 PM
93eg-EKhybrid's Avatar
Default Re: What happens to EBC Green Stuff when used properly (owen_the_soyboy)
Just wondering, where did you get the VTEC rotors drilled at?? I have a set at my house and would like to put them on my car if possible.
Old Mar 6, 2003 | 06:53 PM
Hatchy-Ownzjo0's Avatar
H-T Poker champion
when i was at napa i was just staring at ceramic non-brake-dust pads.. they were calling to me.. but i past them up.
Old Mar 6, 2003 | 07:08 PM
ESCALVANTE's Avatar
Very interesting. I would really like to try these pads now.
What are the specs on your car? Engine, suspension, and brakes please.
Also, how do you like them on the street? I have been looking at Hawk and Panther pads for my M Roadster and VX for Auto-x/Street but after reading this, I think I will go with these pads. I also plan on doing track events so this looks like a worth while pad. I have also been leaning towards this pad because of it's price.
Because of the glazing, do you think you should step up to the Red Stuff pads? I am still deciding on what pads to get as I would like to have good pads for street/Auto-X/track (eventually).
Any input would be great.
Old Mar 6, 2003 | 08:05 PM
fastwanabe's Avatar
Default Re: What happens to EBC Green Stuff when used properly (Hatchy-Ownzjo0)
I ran the EBC green stuff crap for a year and I hated everything about them. here's why.
they dust like a mother, even though they claim low dust
they warped out my rotors way too often
they are somewhat expensive and wore faster than stock pads.
I took them out with 1/4 life left and slapped on some Axxis Metal masters and I have been a happy camper ever since.
EBC greenstuff
Axxis Metal masters
Old Mar 6, 2003 | 09:00 PM
EKhothatch's Avatar
Default Re: What happens to EBC Green Stuff when used properly (fastwanabe)
EBC Green Stuff is crap My buddy had them on his Accord, he hated them. Give them one evening of driving and you'll have a different color wheel, thats for sure.
The funny thing is, he got the Green Stuff pads cuz he didn't want as much dust. Yea, the pads he took off to replace with the Green Stuff pads were definitely EBC Green Stuff pads
Old Mar 6, 2003 | 10:30 PM
ProudtobeANoob's Avatar
there good pads...just dont believe that BS...about no brake dust..cause..they produce a load of it
Old Mar 6, 2003 | 10:39 PM
JDMH22HATCH's Avatar
Default Re: What happens to EBC Green Stuff when used properly (Cosmo)
If you want to talk about brake dust, get some Project Mu. I had some with my c2 on my Integra. I would wash my car in the morning and by the end of the day my wheels went from blingin to gunmeta. Good write up on the pads though. I have heard good and bad, but not enough to make me want to try the pads out until now.
Old Mar 8, 2003 | 01:29 PM
shawnhayes's Avatar
Default Re: What happens to EBC Green Stuff when used properly (93H22HB)
Local machine shop. If you live in VA, Honda-tech instant message me, and I'll tell you who.
Shawn
