is the guy at jiffy lube right or just clueless?
i went to jiffy lube to change my oil today coz i dont' have time anymore to do it myself. anyway, i normally use mobil 1 synthetic. the jiffy lube i went to had only a couple quarts of mobil 1 left. well this guy told me that you're not supposd to mix different brands of synthetic oil. so once you start using one brand, that you have to use that brand from that point on and nothing else.
i never heard of anything like this before. i've mixed mobil 1 and havoline synthetic before and had no problems. does this make any sense to you?
He is just clueless. As long as each of the oils meet the minimum API requirements and are of the same weight, they can be mixed.
[Modified by sharkcohen, 2:27 AM 2/25/2003]
I think he was possibly referring to synthetic and dino oil..
not just different synthetics..
Even then Im not sure the whole dino-->synth theory is true.
your car doesnt burn\use it at all more quickly?
[Modified by sharkcohen, 6:15 AM 2/25/2003]
5W-30 here.
I used to change it according to the owner's manual (every 7500). I'm now changing it every 3k miles since I slapped the blower on.
By the way, is every 3k miles the official recommendation for boosted motors or what?
It's just something I decided to start doing since my motor is now under a lot more stress.
Mine sure does burn the hell out of it. I have to check it more frequently than any car I've ever owned.
Do you guys think that Mobil 1 Synthetic 15w50 would hurt the engine. I recently put it in because a friend of mine told me it would help when drving the car hard. Is it ok, or should i go with something lighter?
heavier oils protect better, but will cause poorer gas milage, not to mention doubling the weight of oil will actually reduce HP by something like 3 percent
nutsack
Sep 5, 2001 11:13 AM
