EG seats and Del Sol seats Help Please
Help me, I just spend an two hours trying to do this, I searched and came up with different answer.
I want to swap seat from a del sol into a eg and eg into del sol.
Right now, I took the passanger side out.
Swap the whole thing on the left and the right only the sliding rail.
Still the eg seat would not fit into the del sol.
Do i have to swap the whole i mean whole thing not just the rails? To get it to fit into the del sol and into the eg?
thanks
thanks
When I put Del Sol's in my hatch, I swapped everything over. Plastic cover was a pain the butt, came off though with some work.
you have to actually pull the handle off... once you pull the plastic part of the handle off you can then just unscrew the plastic cover. also, with ek's you need to swap the rails from the ek onto the delsol seats for them to bolt up. Im assuming you have to do the same for an eg
ok, now handle is off and taking out the whole thing, but i took out 3 bolt, and one last bolt is way inside the seat, do i take that out also, cause the thing isn't coming off yet.
Maybe I can help because I just did a seat swap with my EG but I installed SI seats into my EG but should be the same deal..
Anyways, of course you have to swap the rails from your Del Sol seats onto the EG seats..
You found three out of the four but the last one is found by sliding the seat forward then position the chair upside down and you will see a forth bolt, that should get things out..
I hope..
Well I tried and good luck
I hope..
moores55
Dec 22, 2005 06:07 PM
