lost my NX jetting chart
does anyone know the jetting numbers (N20 and fuel) for a 50 shot (for my civic d16) because i mixed them up and can't find the sheet. thanks
[Modified by tek_civic, 4:59 PM 2/24/2003]
ok how about this, which jet is bigger, the nitrous or the fuel? i have both the jets i used i just can't remember which order they go in. tnx
The Fuel jet size should be 0.022" or 0.555mm
A Nitrous jet size of .037" or 0.9398mm should produce 62 HP
The Fuel jet size should be 0.020" or 0.510mm
A Nitrous jet size of .034" or 0.8636mm should produce 52 HP
The Fuel jet size should be 0.019" or 0.495mm
A Nitrous jet size of .033" or 0.8382mm should produce 49 HP
Yeah I have the same question. Which one goes for the fuel and which for the nitrous. Is it the larger jet for the fuel or for the nitrous. I have the 50 shot pills but I don't know which larger hole jet goes for the fuel or the nitrous nozzle for my NOS wet kit.
thanks a lot for the information that was well described. Perfect example of someone new to honda-tech thats not necessarily a noob how some people think. WELCOME to honda tech. and as you can see above the larger jet is used for nitrous and the smaller is for fuel.
