type r rear swaybar with BSQ style kit/ energy suspension bushings
Old Feb 24, 2003 | 11:34 AM
gribbs's Avatar
Default type r rear swaybar with BSQ style kit/ energy suspension bushings
Would this fit onto a 4 door EG? I have heard the Type R rear will cause sub-frame damage on EGs ...
thanx for any help!
b-rad
Old Feb 24, 2003 | 11:35 AM
gribbs's Avatar
Default Re: type r rear swaybar with BSQ style kit/ energy suspension bushings (gribbsEG8)
o i forgot ....do all tie bars and sway bars from Integras fit civics? or only specific ones??
thanx again
Old Feb 24, 2003 | 11:43 AM
.hugo's Avatar
the sway bars can cause subframe damage, but you should be ok as long as you get the BSQ or beak's reinforcement kit.
Also sway bars from all integs should fit an 92-95 civic as long as the civic has holes for the sway bars in the rear lca. If they don't you can just get the rear lca's of the integra. And the tie bars from 94-00 integs fit 92-95 civics.
Old Feb 24, 2003 | 11:44 AM
gribbs's Avatar
Default Re: type r rear swaybar with BSQ style kit/ energy suspension bushings (starang)
thanx alot man!!
anyone else have comments??
Old Feb 24, 2003 | 12:01 PM
euclid's Avatar
i think all the tie bars will fit too, and make sure you upgrade your front swaybar too to at least an integra diameter(24mm i think), if you dont have a front swaybar at all GET ONE!
vinuneuro
Oct 31, 2005 01:56 AM
base 5th gen
Suspension & Brakes
Feb 6, 2005 09:03 PM
sc_92_civic_hatch
Jan 26, 2004 11:47 AM
evo
Mar 23, 2002 04:15 PM
