Turbo mani- tubular vs. log style
Old Feb 24, 2003 | 11:11 AM
ls-t del sol's Avatar
Default Turbo mani- tubular vs. log style
Is there much of a flow difference when comparing a tubular manifold( not equal length) to a log style?
That is the manifold i will be getting...also does it look like a wastegate will clear a hood on a del sol?
Old Feb 24, 2003 | 11:14 AM
boostin b16's Avatar
Default Re: Turbo mani- tubular vs. log style (SolReaver)
there is no possible way that that wastegate flange will clear the hood! it might just fit if you cut the support of your hood out ...but i doubt it!
Old Feb 24, 2003 | 11:20 AM
Xscream's Avatar
Default Re: Turbo mani- tubular vs. log style (MY"little"T3)
Yeah I don't think that will fit, here is the manifold that I am running (not the exact but damn close)
Edit - yes it is worth it to run a tubular, dosen't crack, flows a lot better!!!
[Modified by Xscream, 2:21 PM 2/24/2003]
Old Feb 24, 2003 | 11:23 AM
Default Re: Turbo mani- tubular vs. log style (Xscream)
thanks for the replies-
is there anything i can do that will allow me to have it clear my hood? BTW i am using the tial 35mm wg...
Old Feb 24, 2003 | 11:53 AM
DXturbo's Avatar
hey xscreamer..... whered you get that manifold? it looks real good!!! i want one too.
Old Feb 24, 2003 | 11:58 AM
turbopimp's Avatar
If you're planning on running that mani on a Del Sol you'll probably need to cut the wastegate neck and have a 90 degree elbow welded on to lay the wastegate on its side...
Old Feb 24, 2003 | 02:41 PM
paulzy's Avatar
Default Re: Turbo mani- tubular vs. log style (redsi37)
PM superT, he's the fabricater...the manifold pictured belongs to one of my buddys
Old Feb 24, 2003 | 02:58 PM
cinq's Avatar
That manifold is wicked...what kind is that? Do they make them for B's?
Old Feb 24, 2003 | 03:05 PM
paulzy's Avatar
Default Re: Turbo mani- tubular vs. log style (cinq)
yeap, they are all made to order with any configuration you want. B, D, H, F, any motor including supras
Old Feb 24, 2003 | 03:32 PM
TheShocker's Avatar
That's my manifold, turbo and DP in this picture. I love it! Contact SuperT ot go to http://www.supertmotorsports.com for more info.
Heres some more pics:
-Seth
Old Feb 24, 2003 | 03:43 PM
Default Re: Turbo mani- tubular vs. log style (turbopimp)
do you think i would be able to weld a mild steel 90 degree bend to that manifold?
[Modified by SolReaver, 12:46 AM 2/25/2003]
Old Feb 24, 2003 | 05:21 PM
turbopimp's Avatar
Hmmm... that mani looks to be made of schedule 40 weld els... it's carbon steel alloy - a common material for fabricated manifold these days. You'll need to get a 1 1/4 " 90 degree elbow and have that welded on after the current wastegate neck is cut off. The elbow is pretty cheap, like 5-10 bucks at an industrial supply shop. Dunno how much a welder is gonna charge for labor though... Oh, and you'll need
a new wastegate flange or else cut and reuse the old one.
Old Feb 24, 2003 | 05:26 PM
the thing is- i already have a 1 3/8 180 degree u bend that i was planning on using for a dumptube...will i be able to cut a 90 degree bend out of this and weld it to the manifold? Its the aluminized mild steel from jc whitney
Old Feb 24, 2003 | 09:17 PM
DXturbo's Avatar
i went to the website and was wondering whats the difference between long and short tubular manifolds? and are there any pics to compare the two? shoot..., i want to get for my apexi IHI ballbearing turbo!
Old Feb 24, 2003 | 09:21 PM
turbopimp's Avatar
I think you'll be better off using the schedule 40 weld el piece cuz it's pretty tough to weld two very different thicknesses of material. The thinner mild steel piece that you have might evaporate before the schedule 40 pipe even warms up... A good TIG welder can probably get the job done, but you'll still end up w/ a mani that has two different types of material in it. Besides the Schedule 40 stuff is so much stronger... wouldn't want the wastegate to snap off the manifold, would we?
Old Feb 24, 2003 | 09:27 PM
TheShocker's Avatar
PM "SuperT" for more info.
Old Feb 25, 2003 | 06:08 AM
Xscream's Avatar
Default Re: Turbo mani- tubular vs. log style (TheShocker)
You can PM dave otherwise his website is http://www.supertmotorsports.com
Old Feb 25, 2003 | 08:39 AM
Overblown-Teg's Avatar
Turbopimp.. That manifold is made from 16g 321 stainless.. That is what the wastgate tube should be made from if your going to modify it. Burnsstainless sells it and I am sure dave at super t can also supply some.
Old Feb 26, 2003 | 02:15 AM
turbopimp's Avatar
Default Re: Turbo mani- tubular vs. log style (Overblown-Teg)
Overblown-Teg, I was responding to the original poster in this thread. The manifold shown in that original post does not appear to be 16 ga. 321 stainless. It *looks* to be schedule 40 carbon steel, which is pretty common material for fabricated manifols these days... Somehow the thread was diverted in focus to the Super T Motorsports manifold, which I believe is fabricated from 321 stainless. If indeed the manifold pictured in the original post is schedule 40 carbon steel then the wastegate neck should be of the same material. If it is 321 stainless then the neck should be 321 stainless... point being that the manifold should be modified with the same type of material...
Old Feb 26, 2003 | 03:10 AM
Sorry- Some how I totally missed the first picture. I just saw all the super T ones. My mistake. Your right it does look like schedule 40 steel.
Old Feb 26, 2003 | 04:40 AM
Screamer's Avatar
TheShocker - Very nice setup you have. Would you be able to take some pictrues as to how you made the pipe connect from your turbo to the Intercooler. I am just wondering about the fitment and spacing.
Thanks.
Old Feb 26, 2003 | 06:45 AM
yellowsub's Avatar
Default Re: Turbo mani- tubular vs. log style (Screamer)
There is no pipe on it. Just a coupler. Gotta hit it from the backside.
Old Feb 26, 2003 | 12:38 PM
TheShocker's Avatar
Thanks.
Sure, I'll take some tonight.
Old Feb 27, 2003 | 08:09 AM
Screamer's Avatar
Thanks
Old Feb 27, 2003 | 05:25 PM
TheShocker's Avatar
i didnt get around to putting everything back together. ive been working on my pain in the *** oil drain. i'll try and get some pics this weekend
