temp gauge
Old Feb 24, 2003 | 10:25 AM
blackfrohatch's Avatar
Default temp gauge
on my 94 ex the temp gauge dosent always move.... sometimes it gose backwards. other times it will barley move. do u think my thermo is bad. or messed up. the rad fan dose come on. sometimes
thanks
justin
Old Feb 24, 2003 | 10:33 AM
twkdCD595's Avatar
Default Re: temp gauge (blackfrohatch)
You could check to make sure both radiator hoses are flowing coolant after fully warmed up (be care to not burn yourself... use a work glove to touch it quickly). If not both flowing your thermostat could be sticking open or closed.
If not that, I would think the sender unit may be not working right or what not.
I would not think it would be the gauge unless you did some upgrades to the factory gauges recently... if the needles get messed with they dont work right.
[Modified by twkdCD595, 1:34 PM 2/24/2003]
Old Feb 25, 2003 | 12:45 PM
Default Re: temp gauge (twkdCD595)
well i left out one more thing it only goes down when i have the heat on...but it goes past it normaly dose when the car is off....but when i dont have the heat on it works normal...??..
Old Feb 25, 2003 | 06:14 PM
95 GaNgStA AcCoRd's Avatar
mine does the exact same thing. I got it pressure tested and they said it was the thermostat. About 2 weeks after that, it started doing it again. When I pop the hood coolant is leaking all over the fan housing, and there is steam comming from 1 specific place at the top of the radiatior, kinda like a jet of air.
Old Feb 26, 2003 | 03:18 PM
Default Re: temp gauge (95 GaNgStA AcCoRd)
mines not leaking....but i am pretty sure it is the thermo now...i guess the only way to find out is to put a new one in..lol
nick1sm
Honda CR-V & Element
Mar 12, 2019 04:17 PM
arejaygsx
Jan 14, 2007 05:10 PM
si 1
Jan 2, 2006 04:48 PM
jpnucrx
Oct 14, 2005 02:24 PM
Quik89Si
23
Jan 11, 2003 11:03 AM
