Finally dynoed my GSR w/ Greddy kit...
Car is a 96 with 142k miles. Mods are 2.5" dp/testpipe and 70mm exhaust, otherwise it's stock. I just wanted a baseline before the Hondata goes in soon. If you can't read it, it's 205.5hp/164.2tq. Not bad I guess, considering the mileage.
which intercooler? can you take some pics of your 2.5" downpipe? particuarly where it exits the turbo...
did you have a wideband looking at your a/f ratio?
falcon: I'm using the Type 24 IC. Downpipe is only after the cast iron elbow, since I want to keep AC for now. Here are some pics:
ohhh right you're that guy.
i am running pretty much same setup except with type 31 IC and AEM engine management.
you have no boost creep issues? i go to full 3" right after the oil pan. no resonator.
Yeah, I remember we talked about this before. No creep issues yet, but I do think my exhaust is somewhat restrictive. I don't plan on setting the boost any higher for a long time, so I'm not too worried.
Unfortunately it wasn't hooked up to a wide band. This was during the IB Dyno day on Saturday and I only got 2 quick passes to establish a baseline. WHen I do the Hondata I'll try to get some A/F info up.
Not bad bro, I dynoed my car there @ 7 psi and got pretty similar numbers, but that was with a thicker headgasket.
[Modified by Andrew 825SM, 12:10 PM 2/24/2003]
i suspect the bloe box is making things hella rich up top and theres another 20-30hp in there. the torque should not start going down at 6000rpm.
Wow, my brother is getting 230hp 190tq with the greddy kit. 8psi. P28 Ecu, Greddy IC. Dynoed a week ago. I am trying to figure out why you getting lower numbers.
from the looks of it everything looks fine. The reason for dabrown getting 230hp 190tq is because you have a tunable standalone (P28), correct? Shaun is getting 206hp with the blue box. i gained around 17hp when i installed the hondata over the blue box at the same psi.
thats more like it. got a dyno chart? i wanna see where the torque typically rolls off on a 18g GSR (well tuned)
At the time of the dyno I was running a GSR motor (in an 96 LX) with:
skunk2 IM
greddy 18g kit
type 24 IC
blue box (unfortunately)
chipped p28 with mugen program
tanabe hyper medallion
12:1 fmu (don't want to hear it)
255 intank walbro pump (again, don't want to hear it)
missing link
stock block
slipping clutch
[edit] forgot VAFC
air/fuel was about 12.2 or thereabouts. I'll get my dyno sheet scanned in tomorrow after class. Corrected numbers were about 239 whp and 189 lb/ft tq. I had 2 baselines done, and that was the best of the 2. Soon to dyno again this sunday and get the fuel leaned out since my blue box is out, and have a 3 inch downpipe (from the turbo) waiting to be installed.
[Modified by Dinuguan, 12:10 PM 2/26/2003]
skunk2 IM
greddy 18g kit
type 24 IC
missing link
stock block
slipping clutch
[edit] forgot VAFC
