Any one in this forum race your ef at the track? Susp. question...
Old Feb 24, 2003 | 08:11 AM
ATS_Antone's Avatar
Default Any one in this forum race your ef at the track? Susp. question...
I want to set me hatch up for road racing. I was wondering what suspension set-ups that you are using. Likes, dislikes, and I should have boughts are welcome. Pics would be cool too. Thanks Anthony
Old Feb 24, 2003 | 08:26 AM
Steve91's Avatar
Default Re: Any one in this forum race your ef at the track? Susp. question... (antone)
I autocross my 91 CRX and do some HPDE. My current setup is off the shelf Koni's with Ground Control 450# Front, 550# Rear. Stock front sway bar, ST Rear. I'm very happy with the setup. It is, however, WAY TO STIFF for a daily driver. I trailer the car to events so the springs are not an issue.
Old Feb 24, 2003 | 09:12 AM
ATS_Antone's Avatar
Thanks for the reply....Anyone else?
Old Feb 24, 2003 | 09:19 AM
Balled S2K's Avatar
You might want to check out the Road Race / AutoX forum here at HT....
https://honda-tech.com/zeroforum?id=19
Also check out http://www.improvedtouring.com
Lots of us tracking Rex's...
Me, I'm using Koni SA Sports, Ground Control sleeves, 500lb springs in front, 700 rear. Suspension Techniques adj. rear sway bar, stock Si front bar.
You'll find good alignment guides on both sites w/ a lil' searching.
Old Feb 24, 2003 | 09:48 AM
89civicdx's Avatar
Default Re: Any one in this forum race your ef at the track? Susp. question... (Balled S2K)
I run 900lbs r and 650f on revalved bilsteins with a type-r bar swaybar in the rear and no front bar. But a good starting setup for springs would be 500r and 400f on some good shocks.
[Modified by 89civicdx, 11:28 AM 2/24/2003]
Old Feb 24, 2003 | 11:54 AM
Outsane's Avatar
don't worry about set up..
I would worry more about driving skill...The more parts you add to the car..
harder it will be to tell what your doing right and what needs improvement..
what ever on th car is not up to stock specs make it rock solid, as it would be off the showroom floor and drive the dog **** out of it..
then mod... my suggestion....
Old Feb 24, 2003 | 12:27 PM
keithv's Avatar
Default Re: Any one in this forum race your ef at the track? Susp. question... (Outsane)
there is some good advice there. learn to drive the car to the limit then mod it...
Subzero ACR
Suspension & Brakes
Dec 25, 2005 10:43 AM
temp
18
May 3, 2004 07:25 PM
teg92
30
Jan 29, 2004 07:35 AM
Todd00
21
Apr 30, 2003 05:51 PM
TurboInteg95
Jun 24, 2002 08:53 AM
