Dunno if you guys can help me out, but i'll ask here anyway.
Old Feb 24, 2003 | 06:30 AM
95CivicDude's Avatar
Default Dunno if you guys can help me out, but i'll ask here anyway.
I recently bought some rims for my 95 civic coupe (dr, 5sp) they are 4 lug, but they DONT FIT MY CAR, omg i was so upset and i cant return them. Yesturday i went to a gathering point here in my town and i saw a 92 - 95 civic HB with the exact same rims, now this may be a dum question but do civic hb and coupe of the same year have different lug pattern? if so, is there a way that i can remedy this without having to sale the rims cuz i would lose a lot on them .
any help is appreciated
Old Feb 24, 2003 | 06:35 AM
Archidictus's Avatar
Unceasing Measure
Default Re: Dunno if you guys can help me out, but i'll ask here anyway. (95CivicDude)
The lug pattern and spacing is no different on the coup and hatchback models. You got screwed, my friend. If the spacing is supposed to be 4 x 100 you probably got 4 x 114 or something. You can figure it out by measuring between the holes (millimeters, center of one hole to the center of the next) and doing the same from center to center of two of your lugs. I forget whether or not you measure across the diagonal for this. Do it both ways...it shouldn't matter. If the measurements are different then your rims will not fit.
You can get em redrilled, but that's really no good.
Old Feb 24, 2003 | 06:43 AM
Default Re: Dunno if you guys can help me out, but i'll ask here anyway. (Archidictus)
this is really weird, i just measured the lugs ditance of the rims that are in my car now and is barely making it to 80mm i dont get it... the other rims (that dont fit) is almost perfect 100... could the previous owner of my car had change the lug pattern? is this even possible?
Old Feb 24, 2003 | 06:47 AM
Spade's Avatar
Are the lugs straight they could be bent.
I believe that almost all hondas are 4X100, I know of none smaller.
Are you measuring from the middle of the lug to the middle of the next? It's not between them but from middle to middle.
Can you get a picture of the rims? Do they have mulitple holes? Or is it just a set of 4?
[Modified by Spade, 7:48 AM 2/24/2003]
Old Feb 24, 2003 | 09:04 AM
Default Re: Dunno if you guys can help me out, but i'll ask here anyway. (Spade)
I'll get some pictures, thanks.
Old Feb 25, 2003 | 12:42 PM
here are the rims
I saw another civic on this board with the same rims on i just dont get why they dont fit.
[Modified by 95CivicDude, 9:43 PM 2/25/2003]
Old Feb 25, 2003 | 12:53 PM
743power's Avatar
hondas only 4 lug bolt patterns are 4x100 and 4x114.3. Measure the spacing on the wheels to see if they are 100mm apart. If they are, I can absolutely garauntee you that the wheels will fit, you are just doing something wrong installing them somehow. Maybe there is a stamp on the wheels that says 4x100 on it.
vivid02's Avatar
The bolt circle on the rims can be for an Accord. What kind or rims are on your car right now? Stock?
Old Feb 25, 2003 | 01:10 PM
Default Re: Dunno if you guys can help me out, but i'll ask here anyway. (743)
yes the rims on my car are stock
Old Feb 25, 2003 | 01:12 PM
Mr. Shifty's Avatar
Default Re: Dunno if you guys can help me out, but i'll ask here anyway. (vivid02)
The rims you bought are for an accord (87+, 4Cyl). Some rims are dual drilled - meaning that the 4x100(civic) and 4x114.3(accord) patterns are on each wheel. Ths wheels you have cannot be redrilled. If a shop sold them to you, they should know that there are 2 different 4-bolt patterns that Honda uses. Good luck.
Old Feb 25, 2003 | 01:25 PM
Spoon Spec EK's Avatar
You got screwed. I would suggest you trying to return them or sell them now.
Old Feb 27, 2003 | 07:00 AM
Default Re: Dunno if you guys can help me out, but i'll ask here anyway. (Spoon Spec EK)
this may be a n00b question which i am but is it possible to do a lug conversion to that of an accord? If it is, will it be less than $400? cuz is more or less what i'm gonna be losing if i do sale does rims with tires
Old Feb 27, 2003 | 07:15 AM
pennies_hatchie's Avatar
sell them and buy another set. and remember to buy 4x100
got sol?
Jun 3, 2013 03:40 PM
Nicram
Oct 17, 2005 08:12 PM
aktuning
Apr 30, 2005 01:01 PM
CivilizedCiv
Apr 6, 2004 02:38 PM
