safest compression to go with
Old Feb 23, 2003 | 08:36 PM
NightHawkC5's Avatar
Default safest compression to go with
what is the safest compression to go with on a b20 block on 91 octane to not crack my sleeves by detonating because i dont want to use race gas
Old Feb 23, 2003 | 08:37 PM
NSX Bob's Avatar
New User
Default Re: safest compression to go with (NightHawkC5)
Hard to say since tuning is such a variable. That will be the key.
Old Feb 23, 2003 | 08:41 PM
Hugh Bowie's Avatar
Default Re: safest compression to go with (Itr00-1374)
9.1 is pretty safe
12.1 is safe if tuned for 91 octane
Old Feb 23, 2003 | 08:46 PM
TREVER's Avatar
Tuning and cams effect it so much and you neglected to tell us your efi system and cam choice. do a search, help yourself.
Old Feb 23, 2003 | 10:15 PM
Default Re: safest compression to go with (TREVER)
ctr cams
Old Feb 23, 2003 | 10:29 PM
Casey's Avatar
id say 12:1 in that case. I had ctrs with 12.5:1+ on 93 and had slight knock at partial throttle in some places. Larger cams will eliminate some of that. Tuning is also key
Old Feb 23, 2003 | 11:37 PM
Default Re: safest compression to go with (Casey)
so if i get lets say skunk stage 2 cams it will help
cause im gonna have 12:0 compression
[Modified by NightHawkC5, 9:56 AM 2/24/2003]
egycasper16
Feb 17, 2011 11:34 PM
steveteggy92
12
Mar 31, 2008 02:39 PM
DevinW
Aug 22, 2003 11:56 AM
desert eagle
Aug 6, 2003 02:05 PM
BlackGSR
Jul 2, 2002 07:02 PM
