type r Brake system???
Old Feb 23, 2003 | 05:58 PM
Nextelbuddy's Avatar
Default type r Brake system???
i have a question. do the type r brake systems have dual piston calipers??? and if they do. was it only in the 97-2000 year models or i mean the ones with the 5 lug setup?? the reason im asking is cuz i can get a the 96 jdm type r system and they are the 4 lug setup with that weird offset. and i was wanting to know if i should get it or should i just get a regular gsr brake setup. cuz i know the gsr setup is only single piston setup and if its the same as the jdm 96 type r then i dont want to wast my money thanx guys for any help
Old Feb 23, 2003 | 05:59 PM
disordeR's Avatar
Default Re: type r Brake system??? (nextelbuddy)
single piston.
96 had the 4 lug set up. 97 and on had 5 lug.
sgT's Avatar
sgT
no ITR came with twin piston calipers.
your 96spec setup is the same as a gsr setup with different lug pattern
Old Feb 23, 2003 | 06:01 PM
sgT's Avatar
sgT
Default Re: type r Brake system??? (disordeR)
single piston.
98+ had 5 lug
Default Re: type r Brake system??? (sgT)
so what u guys are sayin is that the jdm 96 type r brakes are single piston calipers.. right?? or is it dual piston. i know its 4 lug thanx guys
Old Feb 23, 2003 | 06:02 PM
Hybrid ctr's Avatar
single piston
Old Feb 23, 2003 | 06:03 PM
disordeR's Avatar
single piston.
98+ had 5 lug
eh? i swear it was 97+ that had 5 lug.
http://www.itrsport.com/
click technical.
click wheels and tires.
and look under the mag review pics.
[Modified by disordeR, 7:04 PM 2/23/2003]
Old Feb 23, 2003 | 06:05 PM
the reason i ask is because there is a post "guess that brake pad" and the guy had posted pix of pads from a type r and from the pix the back of the pads learly show dual piston marks. (2 circles next to each other)
sgT's Avatar
sgT
click technical.
thats US spec.
you need to decide what you are talking about.
JDM
96spec was 4 lug with gsr sized brakes
98spec was 5 lug
USDM
97+ 5 lug
nothing before that
Old Feb 23, 2003 | 06:07 PM
sgT's Avatar
sgT
He probably used legend or nsx calipers
Old Feb 23, 2003 | 06:10 PM
ok my bad. so the usdm and jdm 98 and up type r's had dual piston setup, but the jdm 96 type r had basicall gsr caliper setup with a different offset lug pattern.
so basically theres no advantage of getting a 96 jdm brake setup other than that its jdm right?
Old Feb 23, 2003 | 06:11 PM
Hybrid ctr's Avatar
they're all single pistons
Old Feb 23, 2003 | 06:13 PM
sgT's Avatar
sgT
Once again, NO ITR had dual piston caliper
but you right, not advantage
Old Feb 23, 2003 | 06:14 PM
Default Re: type r Brake system??? (Hybrid ctr)
ok i beleive you guys im just tryin to figure out why tha pads in the pic above show dual pison marks. and the guy who posted it originally said he got them off his freinds R. is he lying or what... im just curious thats all
Old Feb 23, 2003 | 06:15 PM
Hybrid ctr's Avatar
those pads are off spoon calipers
Old Feb 23, 2003 | 06:24 PM
Padawan's Avatar
Darth ModerVader
The post clearly states that the pads were used with Spoon calipers:
He just got new Spoons calipers installed with these pads...
Old Feb 23, 2003 | 07:09 PM
disordeR's Avatar
click technical.
thats US spec.
JDM
98spec was 5 lug
USDM
97+ 5 lug
nothing before that
okay. failed to mention that the 96 were ONLY in japan. that and didn't know 97 were 4 lug in japan either.
gezzuzz
Mar 16, 2008 01:41 PM
aaaabbbb
Suspension & Brakes
Aug 20, 2005 09:25 AM
Solo2Vtec
Jan 26, 2003 09:39 AM
awskalis04
Nov 20, 2002 05:17 AM
