Does the ECU have anything to do with how the AUTO tranny will shift?
Old Feb 23, 2003 | 04:59 PM
Charlie Moua's Avatar
Default Does the ECU have anything to do with how the AUTO tranny will shift?
well i'm trying to install a 2001 f23a1 into my 1993 accord. It's auto!
Myquestion is this:
*what makes the tranny shift the way it does(pressure, ecu readings, RPM reading?)
If i use the F23a1 with matching AUTO tranny + wired up to an OBD1 94-95 ex auto ecu will it be ok? or will the tranny shift incorrectly due to gearing, ecu not matching with tranny, ect.....
Help me out.
Old Feb 23, 2003 | 09:59 PM
KTeller8's Avatar
Default Re: Does the ECU have anything to do with how the AUTO tranny will shift? (Charlie Moua)
ok from what i know
obd1 trannys have both a TCU *tranny control unit* and and ECU
the tcu will control the transmission and have it shif at its points
the obd2 trannys have the ecu and tcu built into one unit. so the tranny isnt running off its own computer but both the car and tranny off the same
not sure if this is what you want
Old Feb 24, 2003 | 03:45 AM
Default Re: Does the ECU have anything to do with how the AUTO tranny will shift? (KTeller8)
excellent info..
*so would it be ok to use the 94-95 ex vtec accord ECU with a 2001 f23a1 & matching tranny?
*is there any differance in gearing from 2001 and the 94-95 auto trannys?
Old Feb 24, 2003 | 05:20 AM
carolinaACCORD's Avatar
it'll be ok. just make sure you get the wiring right.
i dont know the specific gearing, but there not that much different, so you'll be ok.
Old Feb 24, 2003 | 08:39 AM
Default Re: Does the ECU have anything to do with how the AUTO tranny will shift? (carolinaACCORD)
yeah I'm 98% sure of the wiring but i just don't want the car to drive like it has a torque converter or somthing.. heheh
Old Feb 24, 2003 | 08:44 AM
it does have a torque converter. but anyway, the shift points may be different but i dont think you'll have a problem what-so-ever.
D21X
Feb 3, 2004 03:12 PM
d15bcrex
Jan 15, 2004 09:27 PM
mipawi
Feb 9, 2003 07:46 PM
Tx92AccordExD
Jun 24, 2002 10:10 PM
