i know SOMEONE in here has AEM EMS on a boosted lude besides me
anyone??? it keeps wanting to run ~13.8-14.8:1 a/f under boost, i am trying to figure out how to make it run richer
If you want to fine tune your a/f curve, then do the following. Datalog your a/f's, engine speed, and engine load. Then look over your logs to see what the a/f's are for a particular rpm point. Apply a percentage to get you close to your target and then right click the fuel map/Percent Change/enter calculated value for that particular rpm column. Here is the equation = [(actual/target)x100] , for instance you datalogged 13.8 and want 12.0. Percent change = [(13.8/12)x100]= 115.
XSIintegra
Feb 18, 2005 05:20 PM
beepy
Nov 2, 2004 07:52 AM
