continuing tranny adventures
so we dropped the tranny to change the clutch, everything gravy. reinstalled tranny, mounts, etc. on to the net problem
cant seem to move the clutch arm far enough to the passenger side to reinstall the slave cylinder, any help would rock nads
rob- we-todd-did fo' life
Either the throwout slid off the wider diametyer of the input shaft or the shift fork fell off the ball joint. I'm guessing the latter since I don't think you would be able to get the tranny tightened down if the to bearing was't on right. You put the ends of the fork inside the holders on the bearing right?
Try prying the joint on the shift fork to snap it back onto the ball if it fell off with a long screwdriver inside.
[Modified by sackdz, 3:31 PM 2/23/2003]
thanks sax, i was afraid of something like that
learning is fun
edit: worked!!!! dont have to drop the tranny again
muchos gracias
[Modified by Rob :190:, 3:50 PM 2/23/2003]
learning is fun
muchos gracias
