Hybrid Drag Gen 3 Turbo Kit
Old Feb 23, 2003 | 10:46 AM
B16aef9's Avatar
Default Hybrid Drag Gen 3 Turbo Kit
I have a HYBRID Drag Gen 3 Turbo Kit BRAND NEW!!! Track tested and proven to give your car potential Low12's - High 11's. passes, WHILE RETAINING FACTORY INTERNALS! These kits produced well over 100 HP over stock. Everything you need is included in this special package. The kit comes with an upgraded To4E/T3 60-Trim turbo. Package includes the following...
-Custom spec Turbonetics To4E/T3 turbocharger
-DRAG 4 into 1 Cast Iron Turbo Exhaust Manifold
-TIAL Wastegate Boost adjustable up to 20psi with boost controller.
-Large Spearco front mount intercooler with polished cast aluminum end tanks (the largest intercooler you can fit on Honda without cutting)
-Your choice of a Greddy Type-S, Blitz DD, or HKS SSQ blow off valve
-DRAG Mandrel-Bent Chrome-Plated Piping 2 1/4 IN/ 2 1/2 OUT CHARGE PIPE
-DRAG 2.5" Exhaust Down Pipe
-DRAG Blue Silicone Couplers and Clamps
-High flow secondary inline fuel pump -Vortech 12:1 calibrated boost dependent fuel pressure regulator
-High flow DRAG intake system with funnel ram filter
-Wastegate dump tube (forces the exhaust gases down and away from your air vents)
-Map Sensor Bypass Valves
-Heavy duty black vacuum line
-Steel braided Goodrich dash-8 oil feed line
-Heavy duty insulated oil return line
-All necessary hoses, brass fittings, bolts, clamps and gaskets
Please EMAIL me with any questions you might have or if you would like to purchase the kit.
PROJECTSPEED@AOL.COM
Sacrifice $3000 Shipped once again its BRAND NEW!!
Old Feb 24, 2003 | 06:28 AM
B16aef9's Avatar
Default Re: Hybrid Drag Gen 3 Turbo Kit (B16aef9)
Bump
Old Mar 12, 2003 | 05:34 PM
Tru Dynamix's Avatar
will u part out? i kinda need the "High flow DRAG intake system with funnel ram filter" part. i just need the piping though. let me know if u can part out or get it for me separately
Old Mar 12, 2003 | 07:29 PM
DD_JonnyLee's Avatar
Default Re: Hybrid Drag Gen 3 Turbo Kit (Tru Dynamix)
if your willing to part out, ill take the intercooler piping
-jonathan
Old Mar 12, 2003 | 10:45 PM
mitsuman's Avatar
Default Re: Hybrid Drag Gen 3 Turbo Kit (TrboGSR)
i want the oil feed line! lmk
Old Mar 17, 2003 | 06:57 AM
B16aef9's Avatar
Sorry everyone im not interested in parting out the kit at this time. Thanks to everyone for the emails so far.
Please feel free to email me at ProjectSpeed@aol.com for a detailed list of what comes with this kit and also some 1/4 mile times ran with this same kit.
The kit you would be getting is Brand New
GSR4D
Aug 23, 2005 05:06 AM
QTKEG6
Nov 24, 2004 12:14 AM
01GSRcpe
May 16, 2004 05:17 AM
B16aef9
Feb 24, 2003 06:27 AM
