If snow builds up on the inside part of the rim....
Old Feb 23, 2003 | 10:38 AM
kim_2_da_chee's Avatar
Default If snow builds up on the inside part of the rim....
... am i supposed to get MADDDDDD balance problems? (shake my car a LOT on the highway)
thats the only clue that i can see, but i always thought that if snow gets stuck on the inner rim then it eventually falls off at higher speeds....
god, i thought my lug nuts were loose but they werent..
agree? disagree? i ******* hate this weather
Old Feb 23, 2003 | 10:40 AM
Malgerus's Avatar
Default Re: If snow builds up on the inside part of the rim.... (kim_2_da_chee)
I don't think snow would affect it all that much... but then I haven't driven in the snow on the highway.
Old Feb 23, 2003 | 10:44 AM
Vinceg99's Avatar
Default Re: If snow builds up on the inside part of the rim.... (Mr. S)
Yeah it would affect it. I have had the same problem and then after I took it to a car wash and got it all out it was fine so that would be the only problem that I could have seen it being. You got to think a wheel weight doesnt weigh that much and if one falls off or something your wheel is off balance now take about 2-10 times that weight and stick it on one side of your rim it would for surely affect your wheel balance.
Old Feb 23, 2003 | 10:56 AM
keithv's Avatar
Default Re: If snow builds up on the inside part of the rim.... (Vinceg99)
i've had to pull over on the side of the highway and clean out the snow from my wheel. i've had the worst vibrations from snow being packed to one side of the wheel.
so the long answer is yes, you will get vibrations from the snow making the wheel unbalanced.
Old Feb 23, 2003 | 11:10 AM
Default Re: If snow builds up on the inside part of the rim.... (breaka_1_9)
thank you
now i dont have to worry anymore
Iloveyourhonda92
34
Jun 9, 2010 11:31 PM
valox138
Sep 29, 2008 09:11 AM
Blazin Civic
Jun 27, 2005 01:17 PM
TurBoXBirD16
20
Jun 6, 2002 04:13 PM
type r 01-1063
Jan 27, 2002 07:55 AM
