Camber question (Tein S-tech)
Old Feb 23, 2003 | 08:39 AM
Stryker908's Avatar
Default Camber question (Tein S-tech)
Hey guys would I need a camber kit for my 93 HB, Going to drop on Tein S-tech springs (1.6 drop all around I think ) and KYB AGX shocks....... thanks !
Old Feb 23, 2003 | 09:17 AM
ImportechPerformance's Avatar
Default Re: Camber question (JDM_SIR_II)
its a 1.9 in the front and 1.7 in the back...and yes everytime you modify the suspension you should adjust it accordingly
*edit* by the way this is the exact same thing i have and i posted something up not too long ago....now go search!
[Modified by TheRedSkoolingBus, 11:18 AM 2/23/2003]
Old Feb 23, 2003 | 09:34 AM
poo flinger
Guest
Posts: n/a
No, you should be fine with that drop. And you will need to get an alignment after the install to correct your camber.
Old Feb 23, 2003 | 09:53 AM
Stryker908's Avatar
Default Re: Camber question (I can't believe this ****)
93 hb's dont have adjustable camber ... you can adjust the toe .. but not the camber with out a kit
Old Feb 23, 2003 | 10:27 AM
racingsol's Avatar
i just got camber kit for my del sol , becuase i dropped it and my aliment was always wack and the tires are jsut about bald because of it
exratedaccord93
Sep 8, 2006 06:32 AM
GUNNER666
Jul 28, 2004 08:26 AM
RicedREX
Feb 28, 2004 07:19 AM
631 Teggy
Jan 18, 2003 07:38 AM
