Alternator Belt
loosen the alternator so you can pull the belt off...put the new belt on and push altenator all the way to make the belt tight then tighten down altenator and ur set good luck
if i had my car here i would look for you...when i changed my belt i changed my whole alternator too...just look how it looks now and do the same thing just put the new belt on....honestly...it not like swapping a motor...it will take u 10 min...its really easy...if you have to take off that other belt then just slide it off put the alt. belt on then put the other belt back on and make sure both are tight then tighten the bolt
keithv
Aug 7, 2002 04:40 AM
