Greddy Profec B install help
Old Feb 22, 2003 | 08:49 PM
boosted6thgen's Avatar
Default Greddy Profec B install help
I am installing a profec b on a 97 civic with the Greddy turbo kit. I need to know if the hose coming from the motor into the charge pipe can be hooked up to the extra vacuum nipple on the blow off valve(greddy type s) also? Does the vacuum hose originally into the wastegate become not used? If so, what do you do with it? Please help me with this. thanks
mark
Old Feb 23, 2003 | 11:54 AM
Midwestrider's Avatar
Default Re: Greddy Profec B install help (boosted6thgen)
http://www.greddy.com/technical/profec_frame.htm
http://www.greddy.com/technical/pdf/ProfecB.pdf
hope that ya..ERic
Old Feb 23, 2003 | 12:39 PM
B20-T's Avatar
Default Re: Greddy Profec B install help (Midwestrider)
1-Box to Vacuum source
2-Top to out
3-Charge pipe to in
4-W/G side port to vacuum
Old May 15, 2004 | 10:12 AM
choytim's Avatar
THE GREDDY LINKS DONT WORK ANYMORE.. NEED INSTALL INSTRUCTIONS!!
Old May 15, 2004 | 10:19 PM
SiR Kid's Avatar
New User
Default Re: Greddy Profec B install help (choytim)
I printed them out way back when... PM me what you need and I can look it up and PM or fax the relevant pages to you.
Old May 17, 2004 | 07:02 PM
choytim's Avatar
Default Re: Greddy Profec B install help (SiR Kid)
Thanks a bunch... Ill try to find a fax and ill PM you
shamoo
Apr 29, 2006 09:53 PM
boosted6thgen
Feb 22, 2003 11:30 PM
E-spec Tuner
Jan 25, 2003 11:20 AM
turbod97ex
Jul 22, 2001 09:17 AM
