turbo scooter
I have seen a video of it beating a camero. That thing is fast!!!
lol thats cool shouldnt the carb in front of the turbo?
1) You can use a BOV.
2) You can use an IC.
3) The fuel doesn't have so far to travel.
4) It runs much better at partial throttle.
5) There are more reasons, but I can't think of them right now and do't really care to look for them.
I can say for sure that any one that hops on that thing and races a camero, certinly has a larger set of ***** than i do
SOOO TRUE!
The reason I said that is because just about every turbo setup I have seen on a carbrated car is before. Also if you notice most blowers have carbs on top of them not under them. Not saying you are wronge but to put a turbo on a carb the carb usally goes infront of the turbo. But the points you have are right.
Can some one put up the like to the vid where that thing takes a camaro.
[Modified by Therumblingteg, 5:37 AM 2/23/2003]
My little brother's go-ped is the fastest (loudest) one in the neighborhood. We clocked it at an even 30mph, and it is still scary to ride after I get used to it. The worst part is the barkes. They are just the little clamps off of a bike, but with NO rubber part. They clamp directly on to the wheel and if you do it too hard, over the handle bars you go. the silly thing is, if you use the brakes just enought to slow down with out going over, they are almost worthless.
I made a scooter at school that has a 6 hp motor on it. after a week after i finished building it i broke the wheel spokes. now i have to rebuild the frame to put on a little kids bike tire. that thing was fast while it worked i couldnt floor it otherwise the front would lift up at any speed.
