Can anyone that has a stock or aftermarket LS header sittin around help me out? i need measurements.
Old Feb 22, 2003 | 04:07 PM
JDubya's Avatar
Default Can anyone that has a stock or aftermarket LS header sittin around help me out? i need measurements.
Ok, i just got an Apexi header from a '00 SI. some people were sayin it'll fit fine, i just might have to get my cat extended, and others said it wouldn't even clear the oil pan. so if you have an LS header near by, could you measure the areas shown in the pic? #1: from bottom of head flange to top of bottom pipes, and #2: from head flange to cat flange.
Old Feb 22, 2003 | 04:28 PM
JMX's Avatar
JMX
Default Re: Can anyone that has a stock or aftermarket LS header sittin around help me out? i need measureme
measurment one is 14 in
measurment two i was somewhatr confused on what u wanted:
so i measured diagonally from the middle of the manifold to the cat connector part and i got 20 in.
Old Feb 22, 2003 | 04:33 PM
Brasspremier's Avatar
i think on 2 he wanted distance on the right part of the line
Old Feb 22, 2003 | 04:36 PM
JDubya's Avatar
thanks man. and for the #2 measurement i know it was a little confusing, but i didn't mean diagonal. i meant just the length straight back from the head flange to where the cat flange is (just guestemate where the cat flange would be if it were up even w/the head flange)
Old Feb 22, 2003 | 04:40 PM
JDubya's Avatar
I just measured mine and i'm starting to have doubts about if this header will clear my oil pan/block for #1 i got about 12.5". do you know how much clearance there is between the stock LS header and the oil pan or block? u think this header will fit?
Old Feb 22, 2003 | 09:01 PM
JMX's Avatar
JMX
im not sure if it will fit, ill take another number 2 measurment in the morning for you
later
importdreamer
Apr 27, 2009 11:31 AM
waxbunny
Jun 24, 2006 09:46 PM
Stock R
Jun 19, 2003 07:30 PM
94HybridEX
Apr 11, 2003 05:29 PM
CheezeFrog
Sep 30, 2001 08:25 PM
