GSR Helms manual owners, need assistance
I'm rebuilding a 1996 GSR block. What I need are the specs from the Helms manual. Here are the specific ones I need:
Standard Measurement and Service limits of
Cylinder block
-warpage of Deck
-Bore Diameter and taper
Piston
-Skirt O.D
-Clearence in cylinder
-Ring groove width(Top, 2nd, and oiler)
Piston Ring
-Top and 2nd
-Ring end gap(all 3)
Piston Pin
-Diameter
-Pin to piston clearance
Connecting Rod
-Pin-to-Rod interference
-Small and Large end bore diameters
-End play
Crankshaft
-Mains and Rod diameters
-Rod journal taper
-Journal taper and out of round
-End Play and Total Runout
Bearing
-Main to bearing oil clearances
-Rod bearing to journal clearances
If you could either post them here, email, or IM them I would REALLY appreciate it. If it's easier to scan, that's just as well- everything should be on the same page in the manual.
TIA
[Modified by RAWB, 1:00 PM 2/22/2003]
Cylinder block
-warpage of Deck
Piston
-Skirt O.D
Piston Ring
-Top and 2nd
Piston Pin
-Diameter
Connecting Rod
-End play
Crankshaft
-Rod journal taper
Bearing
TIA
Cylinder Block warpage - b18c1 - standard 0.05mm max. serice limit 0.08mm.
Cylinder Bore size - 81.0mm-81.02mm. service limit 81.07.
Bore Taper - not listed??
don't have time to post rest.. gotta jet. sorry
[Modified by machaf, 11:59 AM 2/23/2003]
prelittlelude
Oct 11, 2003 07:49 PM
