turbo install on my lude
well finally I'm starting to take her apart to get my kit on.... is becoming a pain I tough it would be somewhat easier to take some stuff off... the last bolt in the header to the right is giving me hell i can get nothing in there to take that &*&(* bolt
well here some pic so far what i got done accomplish
oh in these pic there was a hose that i remove from the resonator what I do with it anybody?
that's all so far hopefully my brother gets here soon and can help me before it gets to dark taking some more stuff.....
[Modified by LJR-LUDE01, 10:56 PM 2/25/2003]
About that bolt on the header does it attach to the a-pipe if so use a breaker bar. I was just doing the same thing and yes those bolt are on there, but it you use and breaker bar along with a extension going in from the bottom of the car and use a lot of force it will come off.
well my brother finally came over and help me with the bolt in the header... then on the bottom of the header there are 3 more I took out 2 but the third one thanks to my dad got mess up is strip son now I have to drill the thing
but beside that I'm moving along took out the fuel rail and injectors. I also took out the sparkplugs to be replace too. hmmm took out the condenser fan, the was it is too dark now to do more work on it so tomorrow i have to take out the bike and get me a snake light i think is call or something to use when it gets dark.... I'll post more pics tomorrow afternoon... I still have to work on the fuel tank to put my intak fuel pump. and allot of more stuff
Well I got some good stuff done today.. my brother took the header out and he wire the new clips for my DSM 450 injectors
change my fuel pump for a 255LPH walbro one
I put in the exhaust (sp) manifold attach to the turbo for the first time to start checking how I'm going to run the piping to the i/c and it looks so beatiful
old injectors and sparkplugs
oh almost forgot pick up my muffler from lordvtec...
thanks Robin
hope you sell the rest of your stuff oh and nice bike...
[Modified by LJR-LUDE01, 9:17 PM 2/23/2003]
thanks Robin
hope you sell the rest of your stuff oh and nice bike...[Modified by LJR-LUDE01, 9:17 PM 2/23/2003]
thanks Robin
thanks Robin
see you around!
Didn't get much accomplish today... I when out looking for someone to weld me the fitting for the return line finally found someone but it will be done till tomorrow...
find out I still need a 1/8 npt for my oil feed line and a HKS BOV steel flange ... when to SFP and they didn't have it so I have to call Dynamic Turbo since those are the local shops then is to the internet for it if I can't get it there
tomorrow I'm installing the AEM EMS and my guage pillar while my brother try to install my i/c.. so we can then measure the piping...
change of plan on our list for today... my brother brought my oil pan with the fitting welded so I had to go to the honda dealer for the oil pan gasket come to find out that our prelude don't use a gasket just the honda bond so I got that it was like 22 dollars... came back home install the oil pan.
i had to take the black metal beam that hold my bumper since I drilled hole so i can bolt on my ic then I will also have some pieces welded so it holds good.
you can see the 2 holes closer to the edge on the beam... I need to get some bolts though about 5" long so they go all the way through..
also finish installing my DSM 450 injectors along with the resistor box that I got from sonny. no pics of that I'll take some later.
now on my way out to home depot get me some bolts for my DP and the I/C
[Modified by LJR-LUDE01, 10:55 PM 2/25/2003]
seems like its coming along nicely... gonna have to see it once its all done.. you should have told me you needed the oil lines and fittings.. i had them all there in my garage also... would have saved you the trip..
hey I still neede one at least 1/8 npt to 3 AN .. i know this is part of your oil feed kit but would you be interested in selling it? do you happen to have a hks bov flange tpp somw where?
[Modified by LJR-LUDE01, 7:09 PM 2/25/2003]
well I can't take pic right now need new double A batteries... to get digi camera working.... but I took out my ECU and put in my AEM EMS... although I still go to hack into 2 of the wires to run my boost solenoid and the wideband...
i wish I could just find out all the data I need so I can build my own turbo kit and then put it on my lude
welll today I install the I/C and it looks like I will have to re-locate my power steering cooler thing that's right behind my bumper support... I have to find some hoses longer than the ones that are ther so I can cut some of the pipe and re-routed a different way... also the fitting that I bough in autozone to use on the back of my block broke inside good thing that hole is actually a fitting itself.. so I had to take that out and have my brother drill the piece out.. it work thank god... I was about to go to honda and try to buy a new one... the new sparkplugs are in now too...
Hey lord...where did you get your injectors/box?
I'm doing my install in 55 days...when you get yours done will you post some additional pics (especially the wastegage/boost gauge routing).
If this is towards me... I would write it in spanish since english is not my first language.... but thanks for the comment...
on another note here's more pictures of my progress for today...
the I/c is on
oil pan fitting is welded
the bumper is on for i/c fitment then is coming off again... I don't like the way the I/C sticks out of the bottom but it'll have to stay on like that for now...
passenger side piping
I had to trim by fan...
that's all for today
[Modified by LJR-LUDE01, 7:02 PM 2/27/2003]
the I/c is on
the fan wont be very affective with the shroud gone, go to any local auto parts store and you can get those 12" slim fans for like 60$ a peice and wire them up to push and you can have it on the other side of the radiator. or i guess just wire it up pull and do it behind the radiator, it will still save you lots of room
