started my brake swap
Old Feb 22, 2003 | 12:35 AM
OEMaccord's Avatar
Default started my brake swap
11.8" vs. 10.2"
Had to improvise to seperate axle from hub
Damn axle is 75% of the work
USDM Accord Knuckle vs. UKDM ATR Knuckle
1 down, 3 togo
Old Feb 22, 2003 | 01:14 AM
TypeSH's Avatar
Default Re: started my brake swap (OEMaccord)
sweeeet... exactly what parts are needed and how much?
how much were the ATR knuckles and where did you get them? They bolted up to the stock accord upper and lower ball joints?
which bearings and hub did you use? and which calipers did you use? and which caliper bracket was used?
Old Feb 22, 2003 | 02:58 AM
OEMaccord's Avatar
Default Re: started my brake swap (TypeSH)
I got a complete brake system off ebay. It came with front/rear knuckles, bearings, hubs, rotors, calipers, lines, bascially everything. The front calipers are the same as legend calipers. The rears are the same as a v6 accord. Everything is a direct bolt on, I even used my i-4 brake lins for the legend calipers for the front. Tommorow Im going to put the rears on.
Old Feb 22, 2003 | 07:39 AM
GZERO's Avatar
you could have take the rust off the new rotors, but good job anyway!!
are you sure is an 11.8"??? cuz the AV6 upgrade should be 11.1 or 11.2, i can't remember
Old Feb 22, 2003 | 11:46 AM
OEMaccord's Avatar
Default Re: started my brake swap (GZERO)
Its the same as the 2nd gen CL/CL-S rotor which is 11.8". The rust will come off when I brake.
Old Feb 22, 2003 | 11:52 AM
GZERO's Avatar
i know that the rust on the disc will come off, but the one in the vents won't
Old Feb 22, 2003 | 12:07 PM
OEMaccord's Avatar
vents rust anyways so im not worried
Old Feb 22, 2003 | 01:24 PM
TypeSH's Avatar
are the ATR knuckles any different from the stock accord one? are the caliper mounting holes the same?
I'm wondering if the ATR is using the same hub/bearings/(maybe knuckle too?) as the 1st gen odyssey, but use 11.8" CL type rotors? Sounds interesting if they are the same, something honda grabs out of their parts bin.
I'm hoping this works: Odyssey hub/bearings on an accord knuckle, CL 11.8"/28mm thick rotors , legend dual piston calipesr and bracket (perfectly matched w/ the 28mm wide rotors), and any 5x114.3 wheels w/ the correct offset.
btw, 6th gen accord guys might be able to do the front 5-lug swap by simply getting the v6 rotor/hub/bearings, hondaautomotiveparts lists the same knuckles for the I4 and V6.
[Modified by TypeSH, 10:25 PM 2/22/2003]
Old Feb 22, 2003 | 02:48 PM
OEMaccord's Avatar
This was off a 2000 ATR with around 25k miles. So it was based off the same suspension as a 6th gen accord, 2nd Gen CL/TL. The only difference between them is the caliper mounting holes and where the abs wires are connected to the knuckle.
Old Feb 22, 2003 | 03:06 PM
TypeSH's Avatar
hmm... do you think USDM 6th gen accord V6 or CL/TL knuckles/hub/bearings will bolt up to 5th gens? Those would be easier to get than ATR knuckles.
Old Feb 22, 2003 | 04:48 PM
Hondaaccordvtec's Avatar
I would love to do this but I can't spring for a whole new set of 5 lug wheels and tires. I just got them, what excuses can I give the wife? hmmmmmm............
Old Feb 22, 2003 | 06:10 PM
niedejb's Avatar
Default Re: started my brake swap (Hondaaccordvtec)
Nice work.
Old Feb 22, 2003 | 09:45 PM
OEMaccord's Avatar
Im sure the axle will fit, but don't know about the knuckle fitting the rest of the suspension.
Old Feb 23, 2003 | 12:37 AM
TypeSH's Avatar
so no issues w/ your ATR knuckle and the accord suspension? Have you taken it out for test drives yet?
Old Feb 23, 2003 | 02:39 AM
OEMaccord's Avatar
Nope, although the rear was a pita, I only got one side done today due to bolts not wanting to thread
Old Feb 23, 2003 | 09:19 PM
OEMaccord's Avatar
Ok the rear was a real PITA. After bolting it all on i noticed insane amounts of negative camber. So it has to be an upper control arm doing it. Turn out the upper control arm with a ball joint is an inch shorter than my old one, so this is why it took so long to get the bolt on. After replacing the arm with my old one the install took 5 mins and camber is back to normal. The brake line braket was also too short with the drums, so I had to use the ATRs brackets and bend some hardlines.
Old Feb 23, 2003 | 09:48 PM
TypeSH's Avatar
So your accord originally has rear drum brakes? So you used the rear accord upper control arm but the ATR rear knuckle? were the rear wheel bearings/hub any similar between the ATR and stock ones?
Old Feb 23, 2003 | 10:04 PM
GZERO's Avatar
how does it brakes??
Old Feb 24, 2003 | 12:21 AM
OEMaccord's Avatar
Yeah my car had drums, yeah I used everything from the ATR except the UCA, the hub and bearings seemed to be identical from all the measurements I took.
Still need to do the E-brake, and bleed the brakes.
Circled the control arm and circled where the lines have to be bent, using ATR bracket.
[Modified by OEMaccord, 9:28 AM 2/24/2003]
Old Feb 24, 2003 | 09:58 AM
TypeSH's Avatar
are those black metal rods part of the ATR suspension??? it doestn look anything like the stock accord one w/ a trailing arm ( i think thats what it's called).
Old Feb 24, 2003 | 10:45 AM
OEMaccord's Avatar
this is a 6th gen accord, which has rear 5 link suspension.
Old Feb 24, 2003 | 12:49 PM
After_Burner's Avatar
ok, so in comparison, how would or might this differ from a 5th gen accord? and ATR parts r veeeerry hard to get, especially this part of the world! hehe
Old Feb 24, 2003 | 01:08 PM
OEMaccord's Avatar
Default Re: started my brake swap (After_Burner)
I have not idea,never seen 5th gen suspension in detail. This swap is mostly for 6th gens, and All the ATR components can be obtained here, since they are parts off Legend/CL/AV6
[Modified by OEMaccord, 6:25 AM 2/26/2003]
Old Feb 24, 2003 | 01:11 PM
ok, so for the 5th gen, i could use the odyssey knuckles, integra typeR rotors, on all 4 corners right? i already have the legend calipers!!
Old Feb 24, 2003 | 01:12 PM
isnt the RSX using 11.8inch rotors??
