Road Racing / Autocross & Time Attack Road Racing / AUTOX, HPDE, Time Attack
Mugen front/rear sway & struts (too stiff ?)
Old Feb 21, 2003 | 11:03 PM
feelths's Avatar
Default Mugen front/rear sway & struts (too stiff ?)
i want to build my car for auto-x... i've heard that mugen (26mm) front and rear sway is too much.... i have 2001 GS-R .....
what do you guys recommend i run to stiffin my (stock chassis) ?
Old Feb 22, 2003 | 09:39 AM
Big Phat R's Avatar
Default Re: Mugen front/rear sway & struts (feelths)
If you want to "stiffen" your car - it's the springs/dampers you need to alter first - not the swaybars. This is a common misconception. The Mugen bars are meant to work with (the Mugen) coilovers which have much higher spring rates than stock.
What kind of experience do you have? If you are a novice - keep your car stock - and play with tire pressures only.
What kind of tires does your car have?
[Modified by Big Phat R, 10:39 AM 2/22/2003]
Old Feb 22, 2003 | 11:04 AM
EKhatch's Avatar
I think that Mugen is a little more hardcore than you need. I mean they make a 30mm front bar for the EK, that is one serious piece of equipment.
Good topic more opinions please.
Old Feb 22, 2003 | 06:16 PM
Shmeek's Avatar
Default Re: Mugen front/rear sway & struts (EKhatch)
I've got a Mugen 22mm rear bar with a stiffened suspension and it's ripped through the sub-frame twice. I'd be very careful with that 26mm or 30mm bar.
However, I would say that one of the best suspension modifications you can make is a larger rear sway bar. Even on stock springs/shocks you'll see a big improvement in the handling.
For autocross struts and springs, I'd recommend Koni Yellows and some Ground Control springs. Mix that with the ITR or Mugen rear sway and you've got a great start on suspension for autocross.
ZygSpeed
Feb 6, 2004 08:30 AM
jr_istheman
Jun 4, 2003 08:33 PM
ITR#132
Sep 1, 2002 06:30 AM
2k1TypeR0610
Nov 5, 2001 03:17 PM
paulITR
Oct 4, 2001 08:45 AM
