Swap or Boost?
Old Feb 21, 2003 | 10:35 PM
roydogg's Avatar
Default Swap or Boost?
I have a 94 ls and am wondering if I should boost or do a b18c1 swap. found 1 forsale off a 97 gsr with 45,000 miles on it and it comes complete for 2200. Should I do the swap or buy a maxrev kit?
Old Feb 21, 2003 | 10:38 PM
LsPower's Avatar
Default Re: Swap or Boost? (roydogg)
Build and boost
Old Feb 21, 2003 | 10:49 PM
neo1z's Avatar
Default Re: Swap or Boost? (LsPower)
Build and boost
Undoubtedly.
Old Feb 21, 2003 | 10:51 PM
roydogg's Avatar
But for 2200 I think is a hell of a deal for a gsr motor complete. I'm just confused on what to do. Worry about problems with the turbo or go all motor? The only reason why I'm even thinkin about of a swap is because of the price. Need some suggestions and opinions asap.
Old Feb 21, 2003 | 11:14 PM
roydogg's Avatar
Will my ls I/h/e and cat fit if I do the swap to the gsr? Was also thinkin buy motor and build my ls block to boost next year?
Old Feb 21, 2003 | 11:21 PM
TeamTooQuick's Avatar
Build and boost
Old Feb 21, 2003 | 11:24 PM
roydogg's Avatar
Default Re: Swap or Boost? (TeamTooQuick)
Thats 3 for boost. I think I see the darkside coming . Where's all the all motor guyz at?
Old Feb 21, 2003 | 11:50 PM
neo1z's Avatar
Just wanted to say that I feel like 2200$ for a complete GSR motor/tranny and everything is a bit fishy...
Old Feb 21, 2003 | 11:54 PM
sfr4dr's Avatar
Default Re: Swap or Boost? (neo1z)
If that price is legit I's go for it. Stock reliability is hard to beat even if it's slower.
Old Feb 22, 2003 | 05:30 AM
roydogg's Avatar
Default Re: Swap or Boost? (sfr4dr)
Thats exactly what I'm thinkin. But what would sound better BOV or V-tec? And I can run 5 psi easily and gain more HP, but would it be as reliable?
Old Feb 22, 2003 | 08:18 AM
E-Rok's Avatar
EPIC TUNING
yep.
Old Feb 22, 2003 | 08:27 AM
2k1 GSR's Avatar
Default Re: Swap or Boost? (rewsnaeht)
swap then boost that...
Old Feb 22, 2003 | 08:32 AM
Evilteg's Avatar
Default Re: Swap or Boost? (2k1 GSR)
BLOWN IS BETTER!!!!!!!!!!!!!!!!!!!! WATCH OUT FOR THE ADDICTION
Old Feb 22, 2003 | 10:28 AM
Eckz2k's Avatar
Default Re: Swap or Boost? (Evilteg)
well, id go boost because its only gonna cost a bit more and the BOV sounds so much better then the VTEC, so go for it, and I dont think that the intake and the exhaust will fit on a gsr. or the intake at least.
[Modified by Eckz2k, 7:29 PM 2/22/2003]
Old Feb 22, 2003 | 11:13 AM
beaterman's Avatar
Default Re: Swap or Boost? (Eckz2k)
id go for the swap then super charger it. that would be the best thing to do.
Old Feb 22, 2003 | 11:20 AM
631 Teggy's Avatar
Default Re: Swap or Boost? (beaterman)
Boost the LS... There should be no question here... 2200 for a GSR engine? No sir, the guy selling it is either a jackass, or stole it, or there is someting wrong with it...
Your better off with boost... I got a GSR, engh, nothing special... Boost is the way to go...
SIK IN DA HED's Avatar
New User
is this a trick question?
BOOST of course!
Old Feb 22, 2003 | 11:31 AM
ArizSun21's Avatar
From: Do I look like Michael Bolton from Office Space,, MD, USA
Default Re: Swap or Boost? (SIK IN DA HED)
um...BOOST!!!
Old Feb 22, 2003 | 11:38 AM
Evilteg's Avatar
Default Re: Swap or Boost? (arizsun21)
but make sure its got *** on it, lower the compression so u can boost it more, the kits dont put out very much w stock pistons
Old Feb 22, 2003 | 12:33 PM
illi Adik's Avatar
Build and boost
Old Feb 22, 2003 | 12:53 PM
gumbybum's Avatar
Default Re: Swap or Boost? (Jackson4Door)
boost that shiiiit....
Old Feb 23, 2003 | 01:07 AM
ITR-Spoon's Avatar
i would built it and boost
LS engines are fast
[Modified by Sleepel2_Motol2s, 2:08 AM 2/23/2003]
Old Feb 23, 2003 | 01:33 AM
1OPTION's Avatar
Default Re: Swap or Boost? (Sleepel2_Motol2s)
Build & Boost ... But not the turbo ur talkin bout
Old Feb 23, 2003 | 05:59 AM
2k1_ITR_0736's Avatar
BOTH
Old Feb 23, 2003 | 08:29 AM
4U2NV's Avatar
BOV and open wastegate sound better that VTEC... I'd go boost... I was actually in your same situation about a year ago... I wasn't sure if I should go boost or LS/VTEC, and thankfully I made the choice to go boost...
