need help with parts for s2k antenna conversion
Old Feb 21, 2003 | 08:32 PM
integRacer05's Avatar
Default need help with parts for s2k antenna conversion
i've gone to lowe's twice in the past week trying to get parts for my s2k antenna conversion, the ppl there never know what i'm talking about, i tell them i want:
a coax antenna wire, 1/2" PVC tube, 3 #10 Nuts a 4" long #10 Stud, a #10 Coupling and a large washer (Must be larger than the PVC)
and they have no idea what i'm talking about and half of them dont know wat a coupling is!
i really want to do the conversion so is there any way i could put that parts list into terms that the ppl there will understand, or if there are any other places i should get the materials at, or if ne of you wanta help me out
btw here's a pic of some of the parts:
[Modified by integRacer05, 5:33 AM 2/22/2003]
Old Feb 21, 2003 | 08:55 PM
Aaron M's Avatar
Default Re: need help with parts for s2k antenna conversion (integRacer05)
this probably won't help you but, there is a kit you can buy that has all the parts needed, its about $16 or somthing
Old Feb 21, 2003 | 10:17 PM
nd8ch's Avatar
Default Re: need help with parts for s2k antenna conversion (SilverB18C1)
You dont even need the PVC pipe when you remove your old antenae there should be a metal piece the same shape as the piece your trying to cut. Well my friend did it for me but that's what i remembered.
Old Feb 22, 2003 | 08:15 AM
Default Re: need help with parts for s2k antenna conversion (nd8ch)
whenever i tell them that i need a #10 coupling or whatever, they're like i dont know what #10 is
Old Feb 22, 2003 | 11:10 AM
who sells it?
Old Feb 22, 2003 | 11:37 AM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
the couplings should be located near the full threaded rods and flat and angle aluminum and steel bars.
Instead of using a washer, which will be prone to corrosion, I suggest using a PVC end cap that will fit the piece of angle-cut PVC. FYI I cut the PVC for my antenna at an 18-deg. angle using my dad's miter saw. Then I stuck it into a PVC endcap and drilled a hole in the middle of the cap to fit the stud through. This will hold together better than the PVC glued to a washer. Plus it's less metal in the system which means there are less chances for RF interference.
Old Feb 22, 2003 | 02:11 PM
Default Re: need help with parts for s2k antenna conversion (PatrickGSR94)
where did you get all your parts from
Old Feb 22, 2003 | 02:59 PM
timmy8151's Avatar
Contact RStoR, I believe he sells a parts kit.
01_ITR
Jun 10, 2008 03:13 PM
weakGOODJunKieS.com
Mar 13, 2003 08:11 PM
integRacer05
Feb 17, 2003 01:17 PM
