88 si computer into 88 dx
Old Feb 21, 2003 | 05:50 PM
Java110's Avatar
Default 88 si computer into 88 dx
Can anyone tell me if a computer out of a 88 or 89 CRX si will fit into my 88 CRX dx. The major difference being the si having multiport injection and my dx having throttle body injection, but they are both injected, so I'm not sure if it will work. If not, what year integra ecu will fit, if any. Any info will be greatly appreciated.
Thanx
Old Feb 21, 2003 | 05:54 PM
50shotRex's Avatar
Default Re: 88 si computer into 88 dx (Java110)
u gotta do the mpfi swap using any crx si ecu, or teg.
Spaceballsthelunchbox's Avatar
No Big Whoop
No you cannot use MPFI ECU in your DX.
The only ECU you can use with your current intake manifold is the DX ECU you already have.
You must convert to MPFI to be able to use a PM6 (CRX Si) or PG7 (integra)
Old Feb 21, 2003 | 05:56 PM
Java110's Avatar
ok, thanx for the quick responses
tigueremalo
May 31, 2006 01:08 PM
ricen civic 1
Nov 29, 2004 09:14 PM
theclutchpoppa
May 25, 2003 12:36 AM
freud
Dec 17, 2002 07:27 AM
