Exhaust manifold gaskets and headers? and what to clean carbon build up with?
Old Feb 21, 2003 | 02:57 PM
JDubya's Avatar
Default Exhaust manifold gaskets and headers? and what to clean carbon build up with?
ok, i just got an Apexi header (used) and i need a new manifold gasket. can i just get the stock one from Acura (how much do they usually go for?) or do i have to get an aftermarket one because of the bigger port openings on the header? and should i get a new donut gasket while i'm at it?
and what is a good thing to clean the carbon on the insides of the header? brake cleaner?
Old Feb 21, 2003 | 03:08 PM
Blaze45's Avatar
Brrraaaap!
Default Re: Exhaust manifold gaskets and headers? and what to clean carbon build up with? (ALL MOTOR LS)
get some sand paper and sand it out. make sure the valves are closed and then when you get done vaccum them out, that way none of that crap falls back into the combustion chamber. as for what grit sandpaper you should use, not really sure, do a search. Your EM gasket should fit up, put it up against the head and see, if there is some stickin in the way of the runner, get a dremel and slowly match the gasket to the port. be careful as to take to much off.
Blaze
Old Feb 21, 2003 | 03:19 PM
JDubya's Avatar
Default Re: Exhaust manifold gaskets and headers? and what to clean carbon build up with? (Blaze45)
i actually meant the carbon build up that's inside the header, not on the head itself. but i might clean that too depending on how bad it looks. and so your saying just to get a regular EMG from Acura and dremel it to match the ports on the head/header?
Old Feb 21, 2003 | 03:25 PM
Blaze45's Avatar
Brrraaaap!
yeah should be good, go for it.
Blaze
lostforawhile
Apr 8, 2013 08:27 AM
Psycho719
Oct 22, 2010 11:23 AM
coot_er
Sep 15, 2009 06:43 PM
OH_1fstgsr
Aug 13, 2009 12:40 PM
1994PreludeSi
Jul 11, 2007 10:33 PM
