SRS Light on Dash
Old Feb 21, 2003 | 01:11 PM
abeaujuin's Avatar
Default SRS Light on Dash
I have a 95 Honda Accord EX. I changed my fuel filter (which was hard as hell). After I started the car, the SRS light came on. Does anyone know what connection must have gotten disconnected around that area?
Old Feb 21, 2003 | 02:52 PM
Chiovnidca's Avatar
Default Re: SRS Light on Dash (abeaujuin)
What code does it have stored?
Old Feb 22, 2003 | 11:05 AM
SiK AcC0rD's Avatar
Default Re: SRS Light on Dash (Chiovnidca)
sorry to spill u bad new i think...mine is a 1995 honda accord LX...and my SRS light is on too..but it was b/c i lowered my car. i found out a couple weeks ago that i cannot turn it off (friend from honda says) the airbags on my car has gone bad since the light is on...replacement is like $700..im not doing it
Old Feb 22, 2003 | 08:40 PM
abeaujuin's Avatar
Default Re: SRS Light on Dash (SiK AcC0rD)
That makes no sense that light wasn't on before I changed the fuel filter. It took me 20 minute to change the filter after I started the car back up the SRS light stayed on. I don't think it is not coincedence that the SRS light came on after I change the fuel filter. I know it has to be a plug or a wire I disconnected or something.
Old Feb 22, 2003 | 08:49 PM
Chiovnidca's Avatar
There aren't any SRS wires near the fuel filter. What code does it have stored? That might narrow down the problem.
Old Feb 22, 2003 | 09:42 PM
JiggaFan's Avatar
Get a paper clip.
Go up in the dash panels above your hood release and pull the yellow plug on the wall that's plugged into a "dummy plug" (i.e. no wires coming from the plug). The harness you're pulling should have two grey wires going into it.
Search the net for the "6 second, 4 second, 4 second, 2 blink..." directions on resetting the SRS light. I think it's something like:
1. connect the paper clip to the 2 wire plug (to short it).
2. turn the key to the "on" position (not the first "acc" click and do not start the car on the third click).
3. when the SRS light turns off in SIX (6) seconds, remove the paper clip withing FOUR (4) seconds.
4. from the step above, the light will turn off. again, within FOUR (4) seconds, re-insert the paper clip.
5. from the step above, the lighrt will turn back on. remove the paper clip within FOUR (4) seconds.
6. I believe this is when the light blinks twice. Turn off the ignition for like 10 seconds or something. then turn it on and your SRS light will come on for about 6 seconds (as it should each time you turn the ignition) and then turn off.
[Modified by JiggaFan, 6:47 AM 2/23/2003]
Old Feb 28, 2003 | 10:17 PM
jonj0n1's Avatar
Default Re: SRS Light on Dash (JiggaFan)
will that also work for 6 gen accords?
Old Feb 28, 2003 | 11:53 PM
iam7head's Avatar
Default Re: SRS Light on Dash (jonj0n1)
resetting is the same for 6th gen accord.
same for most of the later honda too actually.
there's two connector look the same for 6th gen accord the harder to reach one is the mes thing..
try to reset it and see what happen.
sometime you got luck and get away for some stuff.
I remove one of my seat in my 6th gen and set off the srs light, i resetted it and
it never come back on.
Old Feb 28, 2003 | 11:55 PM
iam7head's Avatar
Default Re: SRS Light on Dash (iam7head)
my friend's av6 2000 ex got a bad seat belt anchor, when we reset the srs light the light will come back on like after a week, finally got tire of it and went to the dealer, it was a defected part. they fix it for free
Old Mar 2, 2003 | 09:27 PM
jonj0n1's Avatar
i work on my car alarm, sometimes i need to take off the battery. when i reconnect it the srs light comes on all the time. i took it to the dealer while it was under warranty, they helped me reset it. but after warranty was over, they had to charge me. so now its just on all the time.
PaulRi
Dec 8, 2015 05:29 PM
jim109
Aug 2, 2012 06:30 AM
dragracer7383
Aug 28, 2007 04:02 PM
Caveman74
Oct 30, 2006 02:55 PM
sExy_TinKY
Jul 3, 2004 11:06 PM
