SMC/440's/JRSC on a prelude?
Old Feb 21, 2003 | 01:09 PM
kysmith's Avatar
Default SMC/440's/JRSC on a prelude?
OK I've done a search and there does not seem to be much info on it.
Can I run the SMC on a prelude?
Is it not going to work with the JR map mod that comes with the prelude kit? Cuz I need that to retard the timing.
This is my last engine mod for my lude, are 440's too big just to run at 6 psi on a stock kit?
Do I need resistors and clips?
Does anyone have this setup?
Thanks
Old Feb 21, 2003 | 01:35 PM
sharkcohen's Avatar
Default Re: SMC/440's/JRSC on a prelude? (kysmith)
You've asked a few questions here that you didn't on po.com that I can answer. You can run it on your lude. You cannot run it along with the JR "ems" unit. I suggest purchasing an MSD BTM unit for boost/timing control, or even better, a J&S. 440s will be fine. You will need resistors and clips if you do not get saturated injectors. I don't know of anyone who has used the SMC on a JRSC lude, though there might be someone here that has.
Old Feb 21, 2003 | 07:48 PM
kysmith's Avatar
Default Re: SMC/440's/JRSC on a prelude? (sharkcohen)
Thanks, bump
Old Feb 23, 2003 | 01:11 PM
kysmith's Avatar
ttttt
showlude
Mar 12, 2002 12:15 AM
BOO YEAH
Oct 31, 2001 08:49 PM
