best front and rear speakers
can anyone tell me a good set of speakers to replace the front door speakers and rear panel speakers that require no mods fit....a simple screw,plug and play, set will be nice...head unit is pioneer 50w per channel...
car is a 96 integra....
thanks in advance
thanks in advance
no more than a 100 dollarz a set...i was going to just take one front and one rear to best buy for the best similar match but can handle the head unit....i rather just buy a set to screw right in once the olds are taken out...
Just go to crutchfield.com and see what you like. They have a chart of what size speaker will fit it the stock locations. I would stick with infinity, pioneer, sony or polk good but alittle pricey.
and they will go right in correct....ive heard that the speaker mounting hole is shallow and 9 out of 10 times it has to be cut to allow aftermarket speakers to fit....
They should just go in. But you might have to cut the wire and put a crimp on the end for it to slide on the new speaker. Crutchfield says you have 6 1/2s in the front and 6x9s on the rear deck. Just get what you like when you go to best buy and go ask one of the installers in the back if they will fit.
jensen....u gotta be kiddin me...they wont hold up to the stock radios wattage nevermind an aftermarket head unit...
Call your local Circuit City Road Shop............ LOL
Just so you know the thinner the speaker, the easier the install. Hondas are not "big speaker" friendly. So the more High end speakers like Polk or Infinity have big magnets on them, and this requires you to cut out the speaker baskets of your door panel to make them fit. Thinner speakers like Kenwoods or Pioneers will fit like a freakin glove
Hope this helps.
-AK
Hope this helps.
-AK
zenon8890
Audio / Security / Video
10
Oct 27, 2009 02:57 PM
