99 Accord Manual Transmission Question (I-4)
Old Feb 21, 2003 | 05:48 AM
pzoom's Avatar
Default 99 Accord Manual Transmission Question (I-4)
Occasionally, I have a hard time putting the car into forward or reverse. Car is sitting on level ground and the parking brake is off. If I tap the gas, it slides right in. Car has 65K miles on it.
It is more of an annoyance right now, but anyone know if something is wearing/bad and/or needs to be replaced? Is there an adjustment I need to make?
Thanks!
Old Feb 21, 2003 | 06:25 AM
jweller's Avatar
Default Re: 99 Accord Manual Transmission Question (pzoom)
lower your expectations
seriously, this is a very common issue with pretty much all manual trans cars.
When I come up to a stop light, I ususally put the car into 1st before it stops rolling. that pretty much takes care of that one
Old Feb 21, 2003 | 10:49 AM
Kavehman's Avatar
My 98 Honda Accord coupe 5 spd does exactly the same thing. I find it difficult to shift into first, this I find only happens when the car is not running at optimal temperature. Two independant mechanics have told me that this is normal, so live with it.
Old Feb 21, 2003 | 11:43 AM
RotaryBzzz's Avatar
Default Re: 99 Accord Manual Transmission Question (Kavehman)
I remember on my Jetta (very hard to go into first gear until I put in Redline MTL) what helped was:
1) Stopped, clutch pedal up
2) Light turns...
3) Clutch pedal down, select 3rd gear - THEN - 1st gear
4) Clutch pedal up to engage 1st gear - car moving
Old Feb 23, 2003 | 12:06 PM
RIPF23A5's Avatar
Default Re: 99 Accord Manual Transmission Question (RotaryBzzz)
Yeah, its a damn shame, and makes you feel retarded when you think you're in reverse, rev up your engine, and don't move. Boooo
Old Feb 24, 2003 | 09:17 AM
pzoom's Avatar
Default Re: 99 Accord Manual Transmission Question (jweller)
Well that sucks! It does happen more when it is cold, so maybe a fluid change will do the trick. It is just that my Chevy *gasp* that I traded in shifted better into 1st and reverse than my Honda. A bit dissapointing to say the least...
TheHondaJackal
Honda Accord (2013 - 2015)
Nov 23, 2023 10:11 PM
TheGrayt1
Feb 16, 2010 08:15 AM
iplayloudly
Nov 11, 2008 05:51 PM
dave9663
Jun 4, 2007 04:04 AM
