FS: B18C shortblock
jdm b18c type r shortblock. This is basically a bare block. I will include the crank but it needs repaired. It does include the oil pan, windage tray, oil squirters, crank, block, main caps.
the pistons are sold.
$500 and buyer pays shipping.
The sleeves are fine they just need a flex hone to knock the glaze off them. The oil pump gave out on the highway and two of the rod journals were damaged a little along with the rod bearings. But the block itself is fine. CHRIS
tz-devil77 -what all has to be done to put the cable trans in your car
I converted the car from an automatic. I am using the first gen b16a cable transmission. I am running a 92-93 gsr pedals, 92 integra clutch cable. I just drilled the hole int he firewall and ran the cable and it hooked up. The transmission mount that i am using is a modified b16a first gen mount, i didnt have to cut the ears when i do it.
hey upon a little closer inspection to this block i realized that where the thrust washer sits in the bottom of the block for the crank the area is a little rough. The oil pump gave out on this motor and if you run you finger across the surface where the thrust washer sits its a little uneven. I dont know enough about blocks to know if its repairable or not. Most likely it is but i wanted to let everyone know. there is also a little scaring on the casting on the underside of the block also where something had gotten in between the crank and casting but this wouldnt cause any problems.
The only thing for sale still is the shorblock itself, no caps, nothing. Just the block.
i will do it for 300 shipped to the first person i get an email from.
[Modified by g2turbo, 3:36 PM 2/24/2003]
canuck-mx6
Dec 2, 2002 05:16 AM
