Code 6, 10. Replaced sensors, still get code, help
This is on a jdm b20z with a 92 LS intake. I'm using an 88 Si harness in my 90 Si so there are 2 wires not used in the resistor pack. I have them taped off.
As soon as i reset the ecu and click it to the on position, i get codes 6 and 10. I replaced both sensors yesterday and i still get the codes. Does anyone know what pins i check at the ECU? Anyone have any tips to try?
Will these codes prevent open loop?
I will not bother with telling you not to use the 88 harness....but it is done so here goes.
Code 6 - ECT....Pin C6 on the EF harness
Code 10 - IAT.....Pin C5 on the Ef harness.
You are correct, put the right year harness into your vehicle and the codes magically go away. All better!
