need to know how to get water out of headlight.
Old Feb 20, 2003 | 05:16 PM
B00STeD's Avatar
Default need to know how to get water out of headlight.
I got water in my integra headlights and I need to know how to get it out. Please help me I hate this crap.
Joe
Old Feb 20, 2003 | 05:31 PM
animated_life's Avatar
Default Re: need to know how to get water out of headlight. (B00STeD)
how much water? if it's just a little moisture then just turn on your lights and the heat will get rid of the moisture...if it's a lot of water then you have bigger worries than just getting it out. your housing might be cracked....
Old Feb 20, 2003 | 05:53 PM
timmy8151's Avatar
Default Re: need to know how to get water out of headlight. (animated_life)
Open up your headlights, clean it up, then reseal with some silicone sealant. I've heard of people drilling small drainage holes, but I don't know about that. If you want a quick fix, just leave your headlights on for a while or you could use a hairdryer.
Old Feb 20, 2003 | 06:13 PM
NeoGSR's Avatar
Default Re: need to know how to get water out of headlight. (timmy8151)
you could take the headlights out and pour some rubbing alcohol in them and shake them around to get as much water out as possible. the alcohol diplaces water and cleans at the same time....silicone can help seal up leaks
Old Feb 20, 2003 | 06:23 PM
slomofo's Avatar
GDD Member
Take the headlight out and blow the water out with an air gun, then leave it face down in the sun for a few hours. My integra's passenger headlight had that problem, then I wrecked, got a new headlight and the problem went away.
Old Feb 20, 2003 | 06:25 PM
reno96teg's Avatar
i had some condensation in my driver side lights.. i just drove around with my hibeams and lobeams on all day, and that took care of that.
Old Feb 21, 2003 | 04:37 AM
B00STeD's Avatar
Default Re: need to know how to get water out of headlight. (reno96teg)
thanks alot guys I'll have to try some of these.
eight.o.eight.ltd
Jan 28, 2008 12:38 PM
K i l l a B e e.
Aug 7, 2007 08:48 PM
TurboGS-R
Nov 16, 2006 03:08 PM
shockwave
Sep 9, 2003 05:41 PM
fe519
Jul 13, 2003 04:18 PM
