2nd Gen Eclipse turbo in a 6th Gen Accord?
Old Feb 20, 2003 | 04:46 PM
Crono139's Avatar
Default 2nd Gen Eclipse turbo in a 6th Gen Accord?
I know, I know. You're all going to say "wrong forum." Problem is I already tried the Forced Induction section, and got no replies, just a hand full of views. And considering how busy the Forced Induction section is, and that my post is already on the second page, I decided to post here. Here is what I posted earlier.
Can this be done? Recently, I came across a web page, which said that an employee for SpeedCraft was able to put a 2G Eclipse turbo, and Conquest intercooler into a 1994 Accord. Here's the article. http://www.speed-craft.com/Speedgall...d/accord1.html
Old Feb 20, 2003 | 05:06 PM
Brandon's Avatar
Life is Suffering
Default Re: 2nd Gen Eclipse turbo in a 6th Gen Accord? (Crono139)
It's way too small for any serious use. Look for a T3 off of a Ford T-Bird turbo (manual transmission models only, autos got a crappy turbo).
Old Feb 20, 2003 | 05:07 PM
D114's Avatar
It can be done on the F series SOHC engine. The bolt holes dont exactly line up but you can use the manifold from either the first or second gen eclipse and line it up with a gasket, drill and you have a turbo manifold. The problem i see is with the front engine mount and exhaust. Other than that, it'll fit.
Old Feb 20, 2003 | 05:21 PM
Brandon's Avatar
Life is Suffering
Default Re: 2nd Gen Eclipse turbo in a 6th Gen Accord? (D114)
Oh, before I forget, it will not work on any of the cars after 94. The exhaust ports WILL NOT line up at all, it was just a freak coincidence that the F22A/H23A/F22B (DOHC) happened to line up right.
Old Feb 20, 2003 | 05:32 PM
OEMaccord's Avatar
Default Re: 2nd Gen Eclipse turbo in a 6th Gen Accord? (F22Turbo)
This guy, TeamElusive used these for his DSM/Honda motor. Might wanna ask him some questions about it.
http://board.hondasociety.com/showth...ighlight=mitsu
http://board.hondasociety.com/showth...threadid=50274
JDM f22b DOHC Non-VTEC 160HP
2g Eclipse t25 Turbo
2g Eclipse turbo Manifold
Thicker Head Gasket to Lower Compression
Lower Compression Pistons
2g Eclipse 450cc Injectors
2g Eclipse Side Mount Intercooler
MSD 6al with Blaster 3 Coil
Split Second Fuel Management System(Stand Alone)
[Modified by OEMaccord, 2:40 AM 2/21/2003]
Old Feb 20, 2003 | 05:46 PM
Crono139's Avatar
Default Re: 2nd Gen Eclipse turbo in a 6th Gen Accord? (OEMaccord)
Thanks for all of your help. By the way, I just checked DSMTuners for prices on new turbos. This is what I was able to find. Mitsubishi Turbos: Small 16G - $600; Big 16G - $650; 18G - $800; 20G - $1000. Garrett Turbos: T3/T4 Series - $700; Big28 - $750; T28 - $900; Big T28 - $1000. I have no clue what will fit, and what won't. Hopefully, my recent PM to TeamElusive will prove beneficial.
[Modified by Crono139, 3:46 AM 2/21/2003]
Old Feb 20, 2003 | 07:17 PM
CiVic_SiR's Avatar
yes it can be done if your run at like 6 lbs of boost and customize everything and you have to have a five speed tranny
Old Feb 21, 2003 | 12:07 PM
Crono139's Avatar
Default Re: 2nd Gen Eclipse turbo in a 6th Gen Accord? (CiVic_SiR)
It's necessary to have a 5 speed?
hillcsi
Jan 22, 2016 09:13 PM
jbird05ex
May 23, 2004 09:55 PM
