changing belts
Old Feb 20, 2003 | 02:47 PM
jonoknut's Avatar
Default changing belts
how hard is it to change a belt? if they are loose is the belt bad or can it be tightend? thanks
Old Feb 20, 2003 | 03:21 PM
calientecaitlin's Avatar
Default Re: changing belts (jonoknut)
depends on what kind of belt you are changing =\
Old Feb 20, 2003 | 03:49 PM
allmotorls95's Avatar
Default Re: changing belts (calientecaitlin)
Old Feb 20, 2003 | 03:51 PM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
You need to inspect the belts for any signs of wear like cracking or missing ribs, etc. The alternator and PS belts are pretty easy to change. The alternator can be a tight squeeze but it can be done w/o even getting underneath the car. The A/C belt is more difficult because you have to unbolt the lower driver side engine mount underneath the left frame rail, but even then it's not too hard.
Old Feb 20, 2003 | 05:02 PM
EL Vap133's Avatar
Hardest belt to replace is the timing belt...
Old Feb 20, 2003 | 05:52 PM
jonoknut's Avatar
Default Re: changing belts (Vap133)
dont bonk my head. . . yea i need a new alternator belt, how much does it cost? and how do i get it off and/or tighten it?
Old Feb 20, 2003 | 05:55 PM
97gSrkId88's Avatar
well you hvae too get the alternator belt off under the car, id have a mechanic do it they have ifs and it wont cost you alot for labor.
Old Feb 20, 2003 | 06:56 PM
Community Builder
Default Re: changing belts (97gSrkId88)
actually no, like I stated above, I have changed my alternator belt w/o getting under the car. It was a tight squeeze working the belt between the alternator pulley and frame (very little clearance) but I was able to get it through. Of course the other 2 belts will have to come off of the crank pulley to get the alternator belt off.
Old Feb 20, 2003 | 07:22 PM
97gSrkId88's Avatar
Default Re: changing belts (PatrickGSR94)
damn dude you have alot of patience, i use my garages lift and get it from under, alot less stress i think
Old Feb 20, 2003 | 08:03 PM
mugensport9's Avatar
ya JJ u should know that! hey arent volkswagens cool?
Old Feb 20, 2003 | 08:14 PM
jonoknut's Avatar
Default Re: changing belts (mugensport9)
can they be tightend? how much does a new one cost
Old Feb 20, 2003 | 10:37 PM
IN VTEC's Avatar
If a belt has already stretched beyond its usable capacity, you should never readjust the tension back to within spec. It will only strain an only already-stretched belt.
Just get new belts from Pepgirls. $10.00 a belt (dayco).
shorto85
Oct 12, 2005 01:39 PM
failed
Sep 4, 2005 05:59 AM
iNTEGRA-vibe
Jul 29, 2004 10:44 AM
Kato7997
Feb 23, 2003 11:23 AM
