EX gear upgrade - my options?
Hi!
I did Search!
I need some info on this.
Can I use gears from other honda trannies to upgrade my stock EX 95 transmision? I'd like to have shorter gears, to rev high.
Is it possible, and what are my options?
some links if there are any would be appreciated too.
thanks!
I did Search!
thanks!
its possible to interchange gears, but the EX tranny is the best d-series tranny. your options would be gears from the cx, dx, vx trannies, all of which have longer gears, and your other option would be the si gears which i believe, correct me if i'm wrong are the same as the EX.
if you are looking to rev through the gears faster a new lighter flywheel might be the ticket.
[Modified by 96coupe, 1:13 AM 2/22/2003]
Available Stock Ratios
EX/Si
1st-----3.250
2nd-----1.900
3rd-----1.250
4th-----0.909
5th-----0.750 for Si HB and Del sol Si
or------0.702 for 2 dr or 4 dr sedan
Final Drive---4.250
DX
1st-----3.250
2nd-----1.762
3rd-----1.172
4th-----0.909
5th-----0.702
Final Drive---4.058
CX and VX
1st-----3.250
2nd-----1.761
3rd-----1.066
4th-----0.853
5th-----0.702
Final Drive---3.250
i found this site through google http://home.cinci.rr.com/mistab0ne/tranny.html
there is some other good info on the site as well if you want to check it out
[Modified by 96coupe, 8:53 PM 2/22/2003]
EX/Si
1st-----3.250
2nd-----1.900
3rd-----1.250
4th-----0.909
Final Drive---4.250
DX
1st-----3.250
2nd-----1.762
3rd-----1.172
4th-----0.909
5th-----0.702
Final Drive---4.058
CX and VX
1st-----3.250
2nd-----1.761
3rd-----1.066
4th-----0.853
5th-----0.702
Final Drive---3.250
yeah, it's a Mista Bone page.
I'm already in contact with him
My options so far are 92-05 third gear as my forth (reving high) or he just told me about third gear from 89 HF tranny which should be a direct replacement.
JonGP4
Jul 22, 2003 10:10 PM
9KRacer
Jan 19, 2003 06:16 AM
