What do you JDM' ers think about this......?
Old Feb 20, 2003 | 07:19 AM
JDMspecR
Guest
Posts: n/a
Default What do you JDM' ers think about this......?
I have the JDM Conversion and am having the lighting all hooked up professionally with new wiring harness' and relays and aftermarket HID (I know should have bought OEM HID)
But in hooking up the Fog lights- should i have them just wired in to run when the headlights are on- basically always on? Or should i have them it on an aux switch? I know the JDM fog light switch would be optimal, but I dont really go for show and think it might be a waste- Its a daily driven Ichisima ride!
Im sure I would just leave them on all the time anyway- Your two cents is appreciated, even if you think this idea is as gay as boy george...
Also is my aftermarket HID gonna flicker at all? I'll cry a little everyday if not! My buddy has an SI with CTR headlights and even though he has obviously no projectors his HID looks pretty sick- very little flicker though and wide *** spread-
[Modified by JDMspecR, 6:54 PM 2/20/2003]
Old Feb 20, 2003 | 07:39 AM
Padawan's Avatar
Darth ModerVader
Default Re: What do you JDM' ers think about this......? (JDMspecR)
I know the JDM fog light switch would be optimal, but I dont really go for that much show- Its a daily driven Ichisima ride!
You've already gone through all of the expense of doing the JDM conversion, which is a cosmetic modification. If it were me, I would use the JDM foglight switch, or perhaps even the USDM accessory foglight switch.
Old Feb 20, 2003 | 08:19 AM
Reid's Avatar
Global Moderator
One of these things is not like the other ones.
Wire up your foglights however you please, what other people think does not matter.
Old Feb 20, 2003 | 08:27 AM
JDMspecR
Guest
Posts: n/a
Default Re: What do you JDM' ers think about this......? (Reid)
I assume your trying to make a joke about me saying that I'm not in it for full out show purpose- I bought a JDM conversion because its way sicker than the **** USDM front end- not because I wanted to follow this new trend of JDM.... But I respect your opinion curious george....
What is/ does the USDM fog light switch look like? where does it sit? I more or less wanted to know what you guys thought about them being on all the time, sorry If I confused. Because I think I would leave them on whether I had a switch or not!
Old Feb 20, 2003 | 08:28 AM
Reid's Avatar
Global Moderator
I think foglights should only be turned on when there is fog.
I do not understand the fascination with having foglights on just because they are there.
It's ok with modifying your car for aesthetics if that pleases you. You don't need to defend yourself.
Posted by "JDMspecR". LOL
Old Feb 20, 2003 | 08:30 AM
Nate B's Avatar
an Accord is "sicker" than a "**** USDM front"? heh, I thought otherwise, but to each his own
JDMspecR
Guest
Posts: n/a
I totally feel you on that- but for me it's not really a fascination, I just think the housing looks better all lit up! And you missed the point- I 'm not following the trend of JDM I'm JDM because the product is better!
LOL, monkey
[Modified by JDMspecR, 5:42 PM 2/20/2003]
Old Feb 20, 2003 | 08:36 AM
JDMspecR
Guest
Posts: n/a
Default Re: What do you JDM' ers think about this......? (OG Bizzle)
_______
Are you saying you think a JDM conversion looks like an Accord? But I think the Accord housing is tighter than USDM Integra- It looks like a wannabe C- class. Or old *** Celica housing. To each his own though. You have a type R so who gives a ****...! Let me have my wins!
Old Feb 20, 2003 | 09:02 AM
J_Edwards's Avatar
If you are having it all rewired, you can get a regular switch for the foglights that is in a useable location for a lot cheaper than locating the JDM switch. They will both work equally well.
I would only have the fog lights able to turn on with other lights, parking lights or better would be my preference. If you make your car able to have them on all the time (i.e without the other lights on) then you run into legality issues (at least here in cali) plus it would suck to leave your car with your fogs on (becuase nothing would remind you) to return to find your battery dead.
JN who went through all these things, albeit only in his own head, when working with his JDM front end.
Old Feb 20, 2003 | 09:03 AM
PYMUGENITR's Avatar
I wired my JDM conversion headlights to be on whenever the a)driving lights are on, b)HID's are on. Its SICK!
BB1vtec
Jul 8, 2006 05:13 PM
chaskim
May 25, 2006 08:42 AM
simpledc5
14
May 17, 2006 08:23 PM
SteveeeO
Mar 5, 2003 05:50 PM
gsr-2nr
Feb 9, 2003 02:31 AM
